Boolean to control solid visibility
I've looked through the forums but can't seem to find the right code.
For example, I have a boolean parameter called Solid and a solid body called Solid_Body
I would like to be able to do something like feature/component suppression if the boolean value changes, for example:
If Solid = True then
Solid_Body= 1
else
Solid_Body= 0
end if
What would be the code to do something like this?
Thank you
Sergio.D.Suárez
Hi, The following is an ilogic code. For it to work you must have a solid called "Solid_Body", you must have a Boolean parameter called "solid".
If solid is true the solid will be visible, if it is false it will be hidden.
Dim doc As PartDocument= ThisDoc.Document
Dim oCD As ComponentDefinition = doc.ComponentDefinition
For i As Integer = 1 To oCD.SurfaceBodies.Count
	Dim oSolid As SurfaceBody = oCD.SurfaceBodies.Item(i)
	If oSolid.Name = "Solid_Body" Then
		If Solid = True Then
			oSolid.Visible = True
		Else
			oSolid.Visible = False
		End If
	End If
Next i
 I hope the code is useful for you. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
bradeneuropeArthur
Comments removed ...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
