How to create event handler for vault file download, add-in
COLINBRUSCHI
Message 1 of 10
COLINBRUSCHI
Hi All,
I've written an add-in to get out-of-date files from Vault (basic client). If the file has been locally modified, the acquire code wont overwrite the local copy. From what I can gather this behaviour can be changed by setting the PreFileAcquireEventArgs enum to "OK".
The SDK documentation gives the class: AcquireFilesSettings.AcquireFileExtensibilityOptions.PreFileAcquireEventArgs Class
and states:
The result of the PreFileAcquireEvent. This can be set to specify how the acquire of this file should continue.
How does one handle the preacquire event?
The code to acquire as follows:
' Get settings
 Dim oSettings As VDF.Vault.Settings.AcquireFilesSettings = New VDF.Vault.Settings.AcquireFilesSettings(oConnection)
'get
oSettings.DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download
oSettings.AddEntityToAcquire(oFileIteration)
'set the path to the working folder
        oSettings.LocalPath = fldrPath
 oConnection.FileManager.AcquireFiles(oSettings)
Replies (9)
Message 2 of 10
bradeneuropeArthur
you have pre and post events:
AddHandler DocumentService.CheckoutFileEvents.Pre, AddressOf CheckouFileCheckPre
AddHandler DocumentService.CheckoutFileEvents.Post, AddressOf CheckinFileCheckPost
with these handlers:
Private Sub CheckinFileCheckPre(ByVal sender As Object, ByVal e As CheckinFileCommandEventArgs)
'Code
end sub
Private Sub CheckinFileCheckPost(ByVal sender As Object, ByVal e As CheckinFileCommandEventArgs)
'Code
end sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
COLINBRUSCHI
Thanks, I'm still a bit confused though.
If the event is handled by:
AddHandler DocumentService.DownloadFileEvents.Pre, AddressOf preAcquire
How do I access the prefileacquireeventargs, as I guessed in below code:
Private Sub preAcquire(ByVal sender As Object, ByVal e As AcquireFilesSettings.AcquireFileExtensibilityOptions.PreFileAcquireEventArgs)
        e.PreFileAcquisitionResult = AcquireFilesSettings.PreFileAcquisitionResult.OK
    End Sub
This obviously throws an exception since the type of e doesnt match the downloadfileevents handler
Message 4 of 10
bradeneuropeArthur
handler looks like this:
  Private Sub preAcquire(sender As Object, e As DownloadFileCommandEventArgs)
        End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
COLINBRUSCHI
How do you set the PreFileAcquireEventArgs from downloadfilecommandeventargs?
Only the following are accessible
Message 6 of 10
bradeneuropeArthur
with:
            e.FileIds….
        End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 10
COLINBRUSCHI
Sorry, still somewhat lost.
I've added the addhandler line to my download file sub, this should create the link to the handler just before the file is acquired, however the event handler code doesnt run.
' Get settings
        'get
        oSettings.LocalPath = fldrPath 'connection.WorkingFoldersManager.GetWorkingFolder(oFileIteration)
        'Do the download
Do i use the fileIds in a getfilesbyIds type statement? How do I then access the PreFileAcquireEventArgs property?
Message 8 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@COLINBRUSCHI,
Hoping that below youtube link may be helpful.
https://www.youtube.com/watch?v=n9aTyhHjtJk
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 9 of 10
COLINBRUSCHI
It appears you can't monitor events with vault basic...
From SDK documentation:
Availability
This feature is not available in base Vault.  Vault Workgroup, Vault Collaboration or Vault Professional is required.
Message 10 of 10
COLINBRUSCHI
Well the solution wasn't to use an event, it was to configure the following option to force an overwrite:
oSettings.OptionsResolution.OverwriteOption = AcquireFilesSettings.AcquireFileResolutionOptions.OverwriteOptions.ForceOverwriteAll
