How can I turn off the welds in iLogic 2018 ?
Malenki
Malenki
Where is "Weld/Beads/Fillet Weld" item ? Look bottom, please. How can I turn off the welds in iLogic?
Regards
_______________________________________________________
Windows 10 64B + Product Design Collection 2021+ASM 2018
1. HP Z2 Tower G4: Intel Core i7-8700K CPU@3.70GHz + Quadro P2000
2. GIGABYTE EX58-UD5: Intel Core i7 920 (2.66GHz to 3.6GHz) + Quadro FX4000
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Malenki,
Unfortunately, Inventor API does not support to suppress Weld/Bead/Fillet weld. This can be logged into idea station as wish list using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
bradeneuropeArthur
Possible:
Public Sub weld()
Dim a As AssemblyDocument
Set a = ThisDocument
a.ComponentDefinition.Occurrences.Item(1).Visible = False
end sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
