Updating the forms linked parameters
cencinaNB2ET
cencinaNB2ET
In the Forms you create with ilogic.
You can see that if you change the parameter name or the rule name the form wont display them any longer.
is there any way of updating the existing forms linked  parameters or Ilogic rule names?
bradeneuropeArthur
Make use of indirect parameters for I-logic in the parametersbox.
so you are able to change the original Description name to anything you want.
like bellow:
Use the IlogicDescription in your code/form.
And you can change the description without any consequences for the code.
Like below:
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
