Handling DesignViewRepresentation in VB for Inventor
I'am sorry my english is not correct.
I'm trying to understand how the RepresentationsManager and DesignViewRepresentation objects work in vb for inventor.
I would like in defined views in sets, being able to add participants or remove them via the VB.
Or just update the viewing angle ...
Only I can not access the list of elements contained in a view.
I know how to activate a view, lock it or not, renomer ...
Who could guide me? please
Thanks in advance.
MechMachineMan
Hi. Please see the documentation for the answers you seek.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-0EE14ABF-4CAE-44E0-870A-CB2C729100CA
Hopefully it explains itself when you learn the layout of the documentation.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
