I want to create a macro to Auto-Reattach the balloons.
I have the code as below but I get an error on oSelectset.Select(oBalloon). The error says 'Object doesn't support this property or method'.
What do I need to change in my code to make it work?
Thanks in advance!
Dominiek
Public Sub AutoReattachAnnotation() Dim odoc As Document Set odoc = ThisApplication.ActiveDocument If ThisApplication.Documents.Count = 0 Then MsgBox "A document must be open", vbExclamation Else If odoc.DocumentType <> kDrawingDocumentObject Then MsgBox "Must be in Drawing document", vbExclamation Else Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet Dim oSelectset As SelectSet Set oSelectset = oDrawDoc.SelectSet oSelectset.Clear Dim oBalloon As Balloon Dim i As Integer For i = 1 To oDrawDoc.ActiveSheet.Balloons.Count Set oBalloon = oDrawDoc.ActiveSheet.Balloons.Item(i) If oBalloon.Attached = False Then oSelectset.Select (oBalloon) Dim oControlDef As ControlDefinition Set oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("DLxAnnoReconnectCmd") Call oControlDef.Execute oSelectset.Clear End If Next End If End If End Sub
