IF-ELSE-THEN NOT RUNNING PROPERLY-ILOGIC
cameron.frederiksen
cameron.frederiksen
 I realized that Inventor has issues running this code. The code works but if the drawing associated to the assembly model is not updated every time you make a change, it does update your code. So I found that cleaning up my code a bit helped a little. Now the main issue is that when I use
 ThisBOM.OverrideQuantity("Model Data","11000138", "5"I have to refresh the drawing and model and even sometime close the program for it to update the quantities in the BOM. Is there anyway to have this update correctly everytime?
CLAMP SELECTION SEWN ID1 CODE
Component.IsActive("11000063") = False
Component.IsActive("11000064") = False
Component.IsActive("11000065") = False
Component.IsActive("11000066") = False
Component.IsActive("11000067") = False
Component.IsActive("11000068") = False
Component.IsActive("11000069") = False
Component.IsActive("11000070") = False
Component.IsActive("11000071") = False
Component.IsActive("11000138") = False
If O_SEWN And O_CLAMP_SEWN Then
    If (ID1<= 1.25) Or (ID2<=1.25) Then
        Component.IsActive("11000063") = True
        Else
    If (1.75>=ID1 And ID1>1.25) Or (1.75>=ID2 And ID2>1.25) Then
        Component.IsActive("11000064") = True
        Else
    If (2.25>=ID1 And ID1>1.75) Or (2.25>=ID2 And ID2>1.75) Then
        Component.IsActive("11000065") = True
        Else
    If (2.75>=ID1 And ID1>2.25) Or (2.75>=ID2 And ID2>2.25) Then
        Component.IsActive("11000066") = True
        Else
    If (4>=ID1 And ID1>2.75) Or (4>=ID2 And ID2>2.75) Then
        Component.IsActive("11000067") = True
        Else
    If (6>=ID1 And ID1>4) Or (6>=ID2 And ID2>4) Then
        Component.IsActive("11000068") = True
        Else
    If ((7>=ID1 And ID1>6) Or (7>=ID2 And ID2>6)) Then
        Component.IsActive("11000069") = True
        Else
    If (8.25>=ID1 And ID1>7) Or (8.25>=ID2 And ID2>7) Then
        Component.IsActive("11000070") = True
        Else
    If (10>=ID1 And ID1>8.25) Or (10>=ID2 And ID2>8.25) Then
        Component.IsActive("11000138") = True
        Else
    If (12>=ID1 And ID1>10) Or (12>=ID2 And ID2>10) Then
        Component.IsActive("11000071") = True
        Else
'CLAMP >12ID<=24
    If (24>=ID1 And ID1>12) Or (24>=ID2 And ID2>12) Then
         If (7>=VARIABLE_ID1 And VARIABLE_ID1>6) Or (7>=VARIABLE_ID2 And VARIABLE_ID2>6) Then
        Else
        If (8.25>=VARIABLE_ID1 And VARIABLE_ID1>7) Or (8.25>=VARIABLE_ID2 And VARIABLE_ID2>7) Then
        Else
        If (10>=VARIABLE_ID1 And VARIABLE_ID1>8.25) Or (10>=VARIABLE_ID2 And VARIABLE_ID2>8.25) Then
        Else
        If (12>=VARIABLE_ID1 And VARIABLE_ID1>10) Or (12>=VARIABLE_ID2 And VARIABLE_ID2>10) Then
        Else
'Clamp 24>ID<=36
    If (36>=ID1 And ID1>24) Or (36>=ID2 And ID2>24) Then
        If (8.25>=VARIABLE_ID3 And VARIABLE_ID3>7) Or (8.25>=VARIABLE_ID4 And VARIABLE_ID4>7) Then
            ThisBOM.OverrideQuantity("Model Data","11000070", "3")
        Else
        If (10>=VARIABLE_ID3 And VARIABLE_ID3>8.25) Or (10>=VARIABLE_ID4 And VARIABLE_ID4>8.25) Then
            ThisBOM.OverrideQuantity("Model Data","11000138", "3")
        Else
        If (12>=VARIABLE_ID3 And VARIABLE_ID3>10) Or (12>=VARIABLE_ID4 And VARIABLE_ID4>10) Then
            ThisBOM.OverrideQuantity("Model Data","11000071", "3")
        Else
    Else
'Clamp 36>ID<=48
    If (48>=ID1 And ID1>36) Or (48>=ID2 And ID2>36) Then
        If (10>=VARIABLE_ID5 And VARIABLE_ID5>8.25) Or (10>=VARIABLE_ID6 And VARIABLE_ID6>8.25) Then
            ThisBOM.OverrideQuantity("Model Data","11000138", "4")
        Else
        If (12>=VARIABLE_ID5 And VARIABLE_ID5>10) Or (12>=VARIABLE_ID6 And VARIABLE_ID6>10) Then
            ThisBOM.OverrideQuantity("Model Data","11000071", "4")
        Else
'Clamp 48>ID<=60
    If (60>=ID1 And ID1>48) Or (60>=ID2 And ID2>48) Then
        If ((10>=VARIABLE_ID7 And VARIABLE_ID7>8.25) Or (10>=VARIABLE_ID8 And VARIABLE_ID8>8.25)) Then
            ThisBOM.OverrideQuantity("Model Data","11000138", "5")
        Else
        If (12>=VARIABLE_ID7 And VARIABLE_ID7>10) Or (12>=VARIABLE_ID8 And VARIABLE_ID8>10) Then
            ThisBOM.OverrideQuantity("Model Data","11000071", "5")
        Else
cameron.frederiksen
Now I tried using select case and having the user input the quantities and clamp number, but the issue is still the same. I have to keep updated the drawing/model and even having to close the autodesk 2017 program and then It might update the BOM quantities.
'CLAMP SELECTION OVER 12"
If ID1 >12 Then
quantity = ThisBOM.CalculateQuantity("Model Data", "11000063")
quantity = ThisBOM.CalculateQuantity("Model Data", "11000064")
quantity = ThisBOM.CalculateQuantity("Model Data", "11000065")
quantity = ThisBOM.CalculateQuantity("Model Data", "11000066")
quantity = ThisBOM.CalculateQuantity("Model Data", "11000067")
quantity = ThisBOM.CalculateQuantity("Model Data", "11000068")
quantity = ThisBOM.CalculateQuantity("Model Data", "11000069")
quantity = ThisBOM.CalculateQuantity("Model Data", "11000070")
quantity = ThisBOM.CalculateQuantity("Model Data", "11000071")
quantity = ThisBOM.CalculateQuantity("Model Data", "11000138")
Select Case O_CLAMP_ID1
Case "11000063"
Case "11000064"
Case "11000065"
Case "11000066"
Case "11000067"
Case "11000068"
Case "11000069"
Case "11000070"
Case "11000071"
End Select
ThisBOM.OverrideQuantity("Model Data",O_CLAMP_ID1, O_CLAMP_QTY)
cameron.frederiksen
So basically I found that I have to save the Model, then the drawing. Then the drawing says the context is open in another file and I need to save that file so I hit okay and it brings me back to the model where I try to save it, but then it says I need to save from a different level of detail so I then have to go through and save all the level of details, then go back to the illogic level of detail and save that. Once, I do all that I open my illogic form and change the quantities and then they final F***ing update.
cameron.frederiksen
running an event trigger on my illogic rules forced the bom to update.
