Look for equal values in list
I'm currently working on a rule that counts the number of bends in an inventor part. When a bend line is divided by a cut, the rule counts the bend twice. In the picture below, the upper bend will be count twice by the rule, but in production will be set in one go. To filter this error out, I made a second rule that looks for the start and endpoint coordinates of every bend line (rule below). When the coordinates are known, I let the rule calculate the formula of each bend line. The formulas are momentarily exported to Excel because I couldn't get an arraylist to work in the loop. I want to know if it is possible to place the formulas in an array or multivaluelist. The formulas can be numbers only but also a combination of characters and numbers, for example X365.
Now the big problem. To see if two or more bends are on the same line, I have to compare all the formulas with each other. When two or more formulas are equal, they are on the same line. Is it possible to compare multiple values in Ilogic?
Eric
'[ edit these variables as needed sSketchName = "Flat Pattern Sketch" sHoleName = "Locator Holes" oOffset = 0.100 in'defines offset from edge of flat pattern oDiameter = 0.125 in 'defines hole diameter '] ' a reference to the active document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument 'verify document type is sheet metal If oPartDoc.ComponentDefinition.Type <> 150995200 Then MessageBox.Show("File is not a sheet metal part.", "iLogic") Exit Sub End If Dim oCompDef As SheetMetalComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Check to make sure a flat pattern is open. If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then Try If oCompDef.HasFlatPattern = False Then oCompDef.Unfold Else oCompDef.FlatPattern.Edit End If Catch MessageBox.Show("Error editting the flat pattern.", "iLogic") End Try End If ' a reference to the active flat pattern. Dim oFlatPattern As FlatPattern oFlatPattern = ThisApplication.ActiveEditObject 'clean up existing holes Dim oHole As HoleFeature For Each oHole In oFlatPattern.Features.HoleFeatures oHole.Delete Next Dim oFace As Face 'oFace = oFlatPattern.BottomFace oFace = oFlatPattern.TopFace Dim oSketch As PlanarSketch 'clean up existing sketch For Each oSketch In oFlatPattern.Sketches If oSketch.Name = sSketchName Then oSketch.Delete End If Next ' Create a new sketch. The second argument specifies to include/not include ' the edges of the face in the sketch. oSketch = oFlatPattern.Sketches.Add(oFace, False) ' Change the name. oSketch.Name = sSketchName ' Create a new object collection for the hole center points. oHoleCenters = ThisApplication.TransientObjects.CreateObjectCollection Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry Dim oPoint As Point2d Dim oEdge As Edge Dim oEdges As Edges ' Get all Bend UP edges 'where true = top face oEdges = _ oFlatPattern.GetEdgesOfType( _ FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True) 'true = top face 'GoExcel.Open("N:\Drawings\Engineering Productie Tooling\Algemeen\Excel sheets uit Inventor\Test aantal buigingen.xlsx", "Sheet1") ' ''Define Range 'oRowStart = 1 'oRowEnd = 1000 'Dim count As Double 'For count = oRowStart To oRowEnd '' If it's blank count it 'If String.IsNullOrEmpty(GoExcel.CellValue("A" & count)) Then 'i = i + 1 'End If 'Next '' Next empty row is max rows minus blank rows plus one 'oEmptyRow = oRowEnd - i + 1 For Each oEdge In oEdges Dim line As SketchLine = oSketch.AddByProjectingEntity(oEdge) oHoleCenters.Add(oSketch.SketchPoints.Add(line.StartSketchPoint.Geometry, True)) MessageBox.Show(line.StartSketchPoint.Geometry.X &", "& line.StartSketchPoint.Geometry.Y , "Coordinaten startpoint") oHoleCenters.Add(oSketch.SketchPoints.Add(line.EndSketchPoint.Geometry, True)) MessageBox.Show(line.EndSketchPoint.Geometry.X &", "& line.EndSketchPoint.Geometry.Y , "Coordinaten endpoint") GoExcel.Open("N:\Drawings\Engineering Productie Tooling\Algemeen\Excel sheets uit Inventor\Test aantal buigingen.xlsx", "Sheet1") 'index row 1 through 10000 For rowPN = 1 To 10000 'find first empty cell in column A If (GoExcel.CellValue("A" & rowPN) = IsNullOrEmpty) Then 'If (GoExcel.CellValue("A" & rowPN) = IsNotNumeric AndAlso IsNotZero) Then Laatste = rowPN Exit For End If Next 'Tel 0.001 op bij de daadwerkelijke waarde van om deze te kunnen exporteren naar Excel. Wanneer a 0 is, 'ziet Excel dit als een lege cel en dus wordt deze overschreven wanneer een nieuwe a naar Excel wordt geexproteerd Dim a = (line.EndSketchPoint.Geometry.Y-line.StartSketchPoint.Geometry.Y)/(line.EndSketchPoint.Geometry.X-line.StartSketchPoint.Geometry.X) MessageBox.Show(a, "Waarde a") If a > Infinity Or a < -Infinity Then GoExcel.CellValue("N:\Drawings\Engineering Productie Tooling\Algemeen\Excel sheets uit Inventor\Test aantal buigingen.xlsx", "Sheet1", "A" & Laatste) = "X" GoExcel.CellValue("N:\Drawings\Engineering Productie Tooling\Algemeen\Excel sheets uit Inventor\Test aantal buigingen.xlsx", "Sheet1", "B" & Laatste) = line.StartSketchPoint.Geometry.X MessageBox.Show(Laatste, "Cellvalue a=Infinity") ElseIf a = 0 Then GoExcel.CellValue("N:\Drawings\Engineering Productie Tooling\Algemeen\Excel sheets uit Inventor\Test aantal buigingen.xlsx", "Sheet1", "A" & Laatste) = "Y" GoExcel.CellValue("N:\Drawings\Engineering Productie Tooling\Algemeen\Excel sheets uit Inventor\Test aantal buigingen.xlsx", "Sheet1", "B" & Laatste) = line.StartSketchPoint.Geometry.Y MessageBox.Show(Laatste, "Cellvalue a=0") Else GoExcel.CellValue("N:\Drawings\Engineering Productie Tooling\Algemeen\Excel sheets uit Inventor\Test aantal buigingen.xlsx", "Sheet1", "A" & Laatste) = a MessageBox.Show(Laatste, "Cellvalue a=else") Dim b = (line.StartSketchPoint.Geometry.Y-(a*line.StartSketchPoint.Geometry.X)) MessageBox.Show(b, "Waarde b") GoExcel.CellValue("N:\Drawings\Engineering Productie Tooling\Algemeen\Excel sheets uit Inventor\Test aantal buigingen.xlsx", "Sheet1", "B" & Laatste) = b End If GoExcel.Save GoExcel.Close ' LineEquation = a*line.StartSketchPoint.Geometry.X+b ' ' MessageBox.Show(LineEquation, "Vergelijking lijn") line.Delete() Next ' Get all Bend Down edges 'where true = top face oEdges = _ oFlatPattern.GetEdgesOfType( _ FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True) For Each oEdge In oEdges Dim line As SketchLine = oSketch.AddByProjectingEntity(oEdge) oHoleCenters.Add(oSketch.SketchPoints.Add(line.StartSketchPoint.Geometry, True)) MessageBox.Show(line.StartSketchPoint.Geometry.X &", "& line.StartSketchPoint.Geometry.Y , "iLogic3") oHoleCenters.Add(oSketch.SketchPoints.Add(line.EndSketchPoint.Geometry, True)) MessageBox.Show(line.EndSketchPoint.Geometry.X &", "& line.EndSketchPoint.Geometry.Y , "iLogic3") line.Delete() Next
