Geting RangeBOX for local UCS.
edwin.grzybowskiEK8T3
Hi everyone,
I have a macro that gets RangeBOX in global coordination system. See macro below.
Dim dMinX As Double
                             dMinX = oSurfBody.RangeBOX.MinPoint.X
                             Dim dMaxX As Double
                             dMaxX = oSurfBody.RangeBOX.MaxPoint.X
                             Dim RangeX As Double
                             RangeX = dMaxX - dMinX
I would like to have the same but for local UCS created in part file. The question is how to redefine  dMinX to get dMinX_UCS1?
Thanks in advance,
Edwin
chandra.shekar.g
Autodesk Support
Autodesk Support
@edwin.grzybowskiEK8T3,
Hoping that below image would help to predict dMinx_UCS1. Here, dMinx_UCS is calculated as dMinx_UCS = dMinx - UCSx.
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Like".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thank you for answer .  Your solution is fine in case where X and Y axis are parallel. Problem starts when they aren't.
I was thinking about it and get to conclusion that only way to solve that problem for all cases (any location in 3d space, any rotation of UCS axis in reference to WCS) is a transformation of UCS. Making UCS aliened with WCS ergo dMinX=DMin_UCS.
chandra.shekar.g
Autodesk Support
Autodesk Support
Currently, Inventor API does not support to calculate range box with respect to UCS. Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
bradeneuropeArthur
Hi @edwin.grzybowskiEK8T3,
Maybe you should vote this idea:
https://forums.autodesk.com/t5/inventor-ideas/dimension-component-part-and-assembly/idi-p/7523011
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
