Print PDF i-logic stoped working in 2018
Hi all,
My pring to pdf i-logic shows an error when printing to pdf since upgrading to Inventor 2018.
Has anyone had this error message and how did you fix it?
Code attached below;
thanks in advance
SyntaxEditor Code Snippet
Dim PDFAddIn As TranslatorAddIn
PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 4800
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
PDFDirectory = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
If ThisDoc.Path =  "" Then
MessageBox.Show("PDF file not created, click Save button again for PDF creation.", "iLogic")
Return 'exit rule
Else
oDataMedium.FileName = PDFDirectory & "\" & oFileName & ".PDF"
'Publish document.
PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Launch the PDF file in whatever application Windows is set to open this document type with
'i = MessageBox.Show("Preview the PDF file?", "PDF Preview",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
Xun.Zhang
Hi @JaneFan, is there anything changed in Inventor 2018 for it?
Thanks!
Xun
JaneFan
Please try to change one argument in method HasSaveCopyAsOptions(), using Document instead of DataMedium.
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Jane Fan
Inventor/Fusion QA Engineer
Hi Jane,
That works great, thank you for your support. Smiley Happy
