External iLogic rules from Vault
In our company we have a folder in Vault where all iLogic vb-files are stored. On my computer I have manually chosen this folder in the iLogic configuration. I have some models which uses external files, but how do I assure that all users have these external rules locally on the computer? Is there a VB code I can use to retrieve them from Vault, or any way to get these automatically? Also applies to Global Forms.
bradeneuropeArthur
Can you use a public share for these rules?
This makes the situation easier.
For example:
All user use the X:\Rules as network share.
You can perform to check out from vault to this share.
You understand?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
