BOM QTY and Vault
BOM QTY and Vault
BOM QTY and Vault
I have attached a working ilogic code that many people have helped with.
Here is my over all goal.
  • Once a design is finished and checked in.
  • Open the main assembly.
  • Run this BOM Qty code.
  • Print PDFS.
  • Export excel BOMS
The problem that I have this BOM ilogic, is that it asks us to check out all changed parts. I don't want it too!
We can say "no to all" and have the changes be temporary, this is actually the desired change. Because we have some standard parts (library parts) that are used in every new sales order. If some one says yes to one or all, then it gets checked in....someone else sees that its changed, it has to be changed back...etc.
I would like to run the code without having the option to check everything out. Just run the code, it temporally adds the SO and QTY to the parts in the assembly.
Could use some help,
bradeneuropeArthur
Seems to be that you are change the assembly with your code.
See the comments
Sub Main()
    doc = ThisDoc.Document
    Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
    Dim oBOM As BOM = oAssyDef.BOM
'Think this is the issue
'if this is not already set the assembly changes
    oBOM.StructuredViewEnabled = True
    oBOM.StructuredViewFirstLevelOnly = False
    Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
    Dim oBOMRow As BOMRow
    Dim oCompDef As ComponentDefinition
    For Each oBOMRow In oBOMView.BOMRows
      oCompDef = oBOMRow.ComponentDefinitions.Item(1)
      Call SetRowProps(oCompDef, oBOMRow.TotalQuantity)
      If Not oBOMRow.ChildRows Is Nothing
          Call RecurseBOMRow(oBOMRow)
    Next
End Sub
Sub RecurseBOMRow(oBOMRow As BOMRow)
   For Each oBOMRow In oBOMRow.ChildRows
   Next
End Sub
Sub SetRowProps(oCompDef As ComponentDefinition, QTY As String)
 Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
 Dim CompFileNameOnly As String
 Dim index As Integer = CompFullDocumentName.lastindexof("\")
 CompFileNameOnly = CompFullDocumentName.substring(index+1)
 'MessageBox.Show(CompFileNameOnly)
 iProperties.Value(CompFileNameOnly, "Custom", "PartQty") = QTY
 iProperties.Value(CompFileNameOnly, "Custom", "SO") = iProperties.Value("Custom", "SO")
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
