Exporting BOM view scrambles columns
akAMYTB
akAMYTB
Hi All
I'm trying to export the "Structured - All levels" BOM view as an excel workbook. The code below sort of works, but it scrambles the columns. Check out the attachment.
Any help ideas how to fix this?
Cheers - Anders
Dim AssmDoc As AssemblyDocument
Set AssmDoc = ThisApplication.ActiveDocument
Dim BOM As BOM
Set BOM = AssmDoc.ComponentDefinition.BOM
BOM.StructuredViewEnabled = True
BOM.StructuredViewFirstLevelOnly = False
Dim BOMview As BOMview
Set BOMview = BOM.BOMViews.Item("Structured")
BOMview.Export "Test_BOM", kMicrosoftExcelFormat
End Sub
bradeneuropeArthur
what version of inventor are you using?
the file name is not complete?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
philip1009
After setting up the columns the way you want in Inventor, hit the export button, this will export the settings for the BOM as an xml file.  Save the file where it can be easily accessible by all users.
AssmDoc = ThisDoc.Document
BOM.ImportBOMCustomization("FILE PATH AND NAME OF XML FILE HERE")
'Then finish export code.
Sometimes this does work, other times it doesn't.  It's been reported as a glitch to Autodesk many times, somehow something like this takes forever for them to find and fix.
HermJan.Otterman
The way I managed it was by creating a partslist on a drawing and export that, but then you don't have the Tumbnail.
If you use this a lot then try the NXTdim software. there is a trail version.
look at this: https://www.youtube.com/watch?v=7oH3jv_Q094
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Sergio.D.Suárez
This is another example, export a list to excel with a template, and add thumbnails as comments, to make my list more readable in excel, I found it more appropriate than adding the thumbnail because I unnecessarily enlarged the cells. Care must be taken to load the excel template routes well and where the temporary files are stored.
Sub Main()
On Error Resume Next
Dim Dirtemp As String = "C:\Users\Sergio\AppData\Local\Temp\"     '''Specify the path of the temporary folder
Dim Dirxlsx As String = "E:\Libro1.xlsx"                          ''' Specify the template path
Dim osheetbom As String = "BOM"                                   ''' Specify the sheet of the template
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
    ' Set the structured view to 'all levels'
oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
    ' Make sure that the parts only view is enabled.
oBOM.PartsOnlyViewEnabled = True
    ' Establece el tipo de lista de materiales, estructurado o solo partes
Dim oValueList As New ArrayList
oValueList.Add("Structured")
oValueList.Add("Parts Only")
Dim oValue As String
	oValue = InputListBox("Select the type of List to export", oValueList, "Structured", "iLogic", "Selections Available")
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item(oValue)
Dim orden As String = InputBox("Sort to", "Exportar BOM", "Part Number")
oBOMView.Sort(orden, True)' Indicar por medio de que factor se ordenara la lista
oBOMView.Renumber(1, 1)
xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlWorkbook = xlApp.Workbooks.Open(Dirxlsx)
xlWorksheet = xlWorkbook.Worksheets.Item(osheetbom)
Dim row As Integer
row = 3                 ''' Indicate from which row the copying will start to excel
'Dim bRow As bomRow
bRows = oBOMView.BOMRows
For Each bRow In bRows
Dim rDoc As Inventor.Document'Document
rDoc = bRow.ComponentDefinitions.Item(1).Document
Dim rDocName As String = rDoc.DisplayName
Dim m_Camera As Inventor.Camera
m_Camera = ThisServer.TransientObjects.CreateCamera()
If rDoc.DocumentType = kPartDocumentObject Then
  m_Camera.SceneObject = DirectCast(rDoc, PartDocument).ComponentDefinition
Else
  m_Camera.SceneObject = DirectCast(rDoc, AssemblyDocument).ComponentDefinition
End If
m_Camera.Perspective = True
Dim m_TO As Inventor.TransientObjects
m_TO = ThisApplication.TransientObjects
m_Camera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
m_Camera.Fit
m_Camera.ApplyWithoutTransition
ThisApplication.DisplayOptions.NewWindowDisplayMode = DisplayModeEnum.kShadedWithEdgesRendering
ThisApplication.DisplayOptions.Show3DIndicator = False
Dim TumbFilename As String = Dirtemp & rDocName & ".bmp"
m_Camera.SaveAsBitmap(TumbFilename, 800, 600, m_TO.CreateColor(255,255,255))
Dim docPropertySet As PropertySet
docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
'Se seleccionan las columnas de tabla que se exportaran al archivo excel asi como su ubicacion
xlWorksheet.Range("A" & row).Value = bRow.ItemQuantity
xlWorksheet.Range("B" & row).Value = docPropertySet.Item("Part Number").Value
xlWorksheet.Range("C" & row).Value = docPropertySet.Item("Description").Value
With xlWorksheet.Range("B" & row)
            .AddComment
            .Comment.Visible = False
			.Comment.Text(rDocName)
            .Comment.Shape.Fill.UserPicture(TumbFilename)
            .Comment.Shape.Height = 150
            .Comment.Shape.Width = 150
End With
'xlWorksheet.Range("A" & row).Value = bRow.ItemNumber
'xlWorksheet.Range("E" & row).Value = docPropertySet.Item("Cost").Value
'xlWorksheet.Range("F" & row).Value = docPropertySet.Item("Stock number").Value
'xlWorksheet.Range("G" & row).Value = docPropertySet.Item("Vendor").Value
row = row + 1
Next
xlWorksheet.Columns("A:Z").AutoFit
Dim oFileName As String = "Export_" &   oDoc.DisplayName & ".xlsx"
MessageBox.Show(oFileName , "Export to")
xlWorkBook.SaveAs(ThisDoc.Path & "\" & oFileName)'The excel file will be saved in the location of the assembly file
xlWorkbook.Close (True)
xlApp.Quit
 End Sub
By the way your work @HermJan.Otterman  opened many ideas was great. I congratulate you!!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
akAMYTB
Version is 2019.2. You're right about the filename. I just cleaned ip the code for posting to the forum. My real code has the correct filename.
Thanks.
akAMYTB
****... It didn't work for me.
Thanks anyway.
