Derived Part Associative Design View Representation Check or Uncheck
bradeneuropeArthur
Mentor Mentor
Message 1 of 8
bradeneuropeArthur
How can I Check or Uncheck the Option "Associative Design View Representation" for derived part creation, by programming?
The following options are already found, but not the one I search for.
###.ActiveDesignViewRepresentation = "" ' Empty for make no use of any View Rep's
###.oDerivedPartDef.IncludeAllParameters = True or False
###.oDerivedPartDef.IncludeAllSolids = True or False
###.oDerivedPartDef.IncludeAllSurfaces = True or False
###.oDerivedPartDef.IncludeAllSketches = True or False
###.oDerivedPartDef.IncludeAllWorkFeatures = True or False
###.oDerivedPartDef.UseColorOverridesFromSource = True or False
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (7)
Message 2 of 8
cencinaNB2ET
That's the same question I have...
I have this controlling the default view but not sure how to access the true false of associative design?
oDerAssyDef.ActiveDesignViewRepresentation = "Default"
Message 3 of 8
bradeneuropeArthur
I am still searching too...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 8
cencinaNB2ET
The only place i found this porperty : "IsAssociativeDesignView" is on the DerivedFutureAssemblyDefinition?
And on the DerivedPartDefinition.ActiveDesignViewRepresentation property, the API help documentation mentions it but says the following:
"The IsAssociativeDesignView property indicates if an associate link to the design view is created or not."
But no reference as to how you can access it when the property is a string but this property is a boolean??
Its so important to have that because i cant automate the parent assembly and have a derived part show me those changes unless this is ticked as true...
Any Help from Any Autodesk Programmers?
Message 5 of 8
ThomasB44
Hi @bradeneuropeArthur and @cencinaNB2ET
oDerivedAssemblyDef.IsAssociativeDesignView = True
 Seems to work as expected.
Thanks a lot for this post. 😉
Thomas
Mechanical Designer / Inventor Professional 2025
Inventor Professional EESignature
Message 6 of 8
bradeneuropeArthur
What version of inventor are you using?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
ThomasB44
I'm using IV2021 with last updates.
Thomas
Message 8 of 8
cencinaNB2ET
I was using the same version when i tried this initially.
I abandoned that particular workflow because of these issues, but will have a closer look at it later when i have time.
Thank you.
