insert on mouse position
Could anyone help me to modify this code, so a new part enters in the assembly where the mouse cursor is at that moment instead of on point 50,50,50?
Many thank
'[ Place Component
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create Matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
'insert new occurence
Dim oOcc As ComponentOccurrence
oOcc = oAsmCompDef.Occurrences.Add( _
oPathandName, oMatrix)
oOcc.Grounded = False
ThisDoc.Document.SelectSet.Select(oOcc)
Or that it "hangs" on my mouse and is placed where I click in the assmebly....
Sergio.D.Suárez
Try a code like this, add the dialog box to select the piece and try it, but you just have to put the last lines and identify the selected file
Dim oFileDlg As Inventor.FileDialog
ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
oFileDlg.FilterIndex = 1
oFileDlg.DialogTitle = "Select Part or Asssembly"
oFileDlg.InitialDirectory = ThisDoc.Path
oFileDlg.InsertMode = False
oFileDlg.MultiSelectEnabled = False
oFileDlg.SuppressResolutionWarnings = True
oFileDlg.CancelError = False
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
MessageBox.Show("File not chosen.", "Dialog Cancellation")
ElseIf oFileDlg.FileName <> "" Then
selectedfile = oFileDlg.FileName
MessageBox.Show("File " & selectedfile & " was selected.", "Dialog Selection Made")
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,selectedfile)   ' for example   "\\samba\diseño\Inventor\530 CABALLETES\530.09_D\530.09D.05.12 Parante B.ipt"
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
 I hope I can help you, regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you, but the part is already (automatically) chosen.
Sergio.D.Suárez
If I understand, that's why I told you to take the line below, and put your "oPathandName" and I think it will do what you need
oPathandName = "\\samba\diseño\Inventor\530 CABALLETES\530.09_D\530.09D.05.12 Parante B.ipt"
ThisApplication
.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,oPathandName) ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
Mechanical Designer
i added those 2 lines to my code and removed a few from the original and it seems to work. many Thanks!
'[ Place Component
' Create Matrix
'Dim oOcc As ComponentOccurrence
'oOcc = oAsmCompDef.Occurrences.Add( _
'oPathandName, oMatrix)
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,oPathandName)
'oOcc.Grounded = False
'ThisDoc.Document.SelectSet.Select(oOcc)
