Export Drawing dimension to excel
eladm
Message 1 of 35
eladm
Hi
I need help with ilogic rule to export all drawing dimensions to Excel
Not VBA , some of the dimeson  have tolerance
regards
Replies (34)
Message 21 of 35
eladm
Hi
Can the code not will be :
The desire :
Message 22 of 35
bradeneuropeArthur
Sure hang on!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 23 of 35
bradeneuropeArthur
AddReference "Microsoft.Office.Interop.Excel.dll" Imports exe = Microsoft.Office.Interop.Excel 'Dim oXLFile As String = "C:\TEMP\DrawingDimensions.xlsx" Dim oSheet As String = "Sheet1" Dim oExcel As New Microsoft.Office.Interop.Excel.ApplicationClass Dim oWB As Microsoft.Office.Interop.Excel.Workbook = oExcel.Workbooks.add'.Open(oXLFile) Dim oWS As Microsoft.Office.Interop.Excel.Worksheet = oWB.Worksheets.Item(oSheet) Dim oCells As Microsoft.Office.Interop.Excel.Range = oWS.Cells 'oCells.item(2,1).value= b.Text.Text.ToString Dim a As Inventor.DrawingDocument = ThisDrawing.Document Dim s As Inventor.Sheet = a.ActiveSheet Dim i As Integer = 1 For Each b As Inventor.DrawingDimension In s.DrawingDimensions 	i = i + 1 'MsgBox (b.Text.Text & " " & b.Tolerance.ToleranceType) 	 	If b.Tolerance.ToleranceType = 31236 Then 		oCells.item(i,1).value = b.Text.Text 		oCells.item(i,2).value = b.Tolerance.Upper*10 		oCells.item(i,3).value = b.Tolerance.Lower*10 	 		oCells.item(1,1).value = "Dimension" 		oCells.item(1,2).value = "Tolerance Upper" 		oCells.item(1,3).value = "Tolerance Lower" 		End If If b.Tolerance.ToleranceType = 31233 Then 		oCells.item(i,1).value = b.Text.Text 		oCells.item(i,2).value = b.Tolerance.Upper*10 		oCells.item(i,3).value = b.Tolerance.Lower*10 	 		oCells.item(1,1).value = "Dimension" 		oCells.item(1,2).value = "Tolerance Upper" 		oCells.item(1,3).value = "Tolerance Lower" 		End If If b.Tolerance.ToleranceType = 31235 Then 		oCells.item(i,1).value = b.Text.Text 		oCells.item(i,2).value = "" & b.Tolerance.Upper*10 		oCells.item(i,3).value = "" &b.Tolerance.Lower*10.ToString 	 		oCells.item(1,1).value = "Dimension" 		oCells.item(1,2).value = "Tolerance Upper" 		oCells.item(1,3).value = "Tolerance Lower" 		End If 	Next 	oWB.saveas("C:\TEMP\"& a.DisplayName & ".xlsx") oWB.close
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 24 of 35
eladm
sorry , the min value is zero
Message 25 of 35
bradeneuropeArthur
We are Coming closer!
	i = i + 1
		oCells.item(i,2).value = "+" & b.Tolerance.Upper*10
		oCells.item(i,3).value  = "-" &b.Tolerance.Lower*10.ToString
	Next
oWB.close
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 26 of 35
eladm
same result
Message 27 of 35
_dscholtes_
@bradeneuropeArthur Why are you setting the column headers with each dimension?
Message 28 of 35
bradeneuropeArthur
Modified:
Heading
and the minus sign added.
	i = i + 1
	Dim du As Double = "+" & (b.Tolerance.Upper * 10)
	Dim dl As Double = "-" & (b.Tolerance.Upper * 10)
	'MsgBox("+"&(b.Tolerance.Upper*10).ToString)
		oCells.item(i,2).value = du '"="+"" &(b.Tolerance.Upper*10)'"p"'"+" & b.Tolerance.Upper*10
		oCells.item(i,3).value  = dl'"-" &(b.Tolerance.Lower*10)'"q"'"-" &b.Tolerance.Lower*10
	Next
oWB.close
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 29 of 35
eladm
Hello
This is great , but why it not detect ref. / basic / limit dimension ?
Message 30 of 35
bradeneuropeArthur
Try this.
	i = i + 1
If b.Tolerance.ToleranceType = 31246 Then
		oCells.item(i,1).value = (Replace((Replace(b.Text.Text.ToString,"(","")),")",""))'Replace(b.Text.Text.ToString,"-","")
	Next
oWB.close
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 31 of 35
eladm
thank you very much
Message 32 of 35
eladm
Hello
Do you know , why instead to get the diameter symbol , the excel get the letter n ?
regards
Message 33 of 35
chuck.bardsley
Is there a way to do this for ordinate dimensions.  Where each dim would export as X,Y?
Chuck B.
Message 34 of 35
bradeneuropeArthur
You mean if horizontal then there is an x dimension
and if vertical there is an Y dimension?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 35 of 35
chuck.bardsley
That is correct
Chuck B.
