Export Drawing dimension to excel
eladm
Message 1 of 36
eladm
Hi
I need help with ilogic rule to export all drawing dimensions to Excel
Not VBA , some of the dimeson  have tolerance
regards
Replies (35)
Message 2 of 36
aelqabbany
Could you upload a non-confidential drawing so that I can take a look?
Message 3 of 36
bradeneuropeArthur
Dim a As Inventor.DrawingDocument = ThisDrawing.Document
Dim s As Inventor.Sheet = a.ActiveSheet
Dim i As Integer = 1
For Each b As Inventor.DrawingDimension In s.DrawingDimensions
	i=i+1
	GoExcel.CellValue("C:\TEMP\DrawingDimensions.xlsx", "Sheet1", "A" & i) = b.Text.Text.ToString
	Next
Try this:
Make in your C:\Temp\DrawingDimenions.xlsx as new file first!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 36
eladm
Hi
Not working
The Sheet excel is empty
Message 5 of 36
bradeneuropeArthur
Can you make a screenshot of the Excel sheet.
is the sheetname "sheet1"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 36
bradeneuropeArthur
	i=i+1
	GoExcel.Save
	Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 36
bradeneuropeArthur
forgot the SAVE!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 36
eladm
Hi
Ok , it takes the dimension , great , but I also need the tolerance ( only some of the dimension)
I must have dimension with tolerance to excel
regards
Message 9 of 36
bradeneuropeArthur
	i = i + 1
	'MsgBox (b.Tolerance.Upper)
	GoExcel.CellValue("B" & i) = b.Tolerance.Upper
	GoExcel.CellValue("C" & i) = b.Tolerance.Lower
	GoExcel.Save
	Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 36
bradeneuropeArthur
And with a Heading will be your next question:
	i = i + 1
	GoExcel.CellValue("A" & 1) = "Dimension"
	GoExcel.CellValue("B" & 1) = "Tolerance Upper"
	GoExcel.CellValue("C" & 1) = "Tolerance Lower"
	GoExcel.Save
	Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 36
eladm
Hi
The next question is the name of the excel with the name of the file 🙂
but ,See the problems
1)dim with symmetric
Message 12 of 36
bradeneuropeArthur
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports exe = Microsoft.Office.Interop.Excel
Dim oXLFile As String = "C:\TEMP\DrawingDimensions.xlsx"
Dim oSheet As String = "Sheet1"
Dim oExcel As New Microsoft.Office.Interop.Excel.ApplicationClass
Dim oWB As Microsoft.Office.Interop.Excel.Workbook = oExcel.Workbooks.Open(oXLFile)
Dim oWS As Microsoft.Office.Interop.Excel.Worksheet = oWB.Worksheets.Item(oSheet)
Dim oCells As Microsoft.Office.Interop.Excel.Range = oWS.Cells
oCells.item(2,1).value= "sjgjsagjlk"'b.Text.Text.ToString
	i = i + 1
'	'MsgBox (b.Tolerance.Upper)
oCells.item(i,1).value = b.Text.Text.ToString
oCells.item(i,2).value = b.Tolerance.Upper
oCells.item(i,3).value  = b.Tolerance.Lower
oCells.item(1,1).value  = "Dimension"
oCells.item(1,2).value = "Tolerance Upper"
oCells.item(1,3).value = "Tolerance Lower"
'	GoExcel.Save()
	Next
	oWB.saveas("C:\TEMP\"& a.DisplayName & ".xlsx")
oWB.close
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 36
eladm
Hi
The tolerance is divided by 10
for example : 100+0.2 = the result is 0.02
Message 14 of 36
bradeneuropeArthur
We are coming closer:
	i = i + 1
oCells.item(i,2).value = b.Tolerance.Upper*10
oCells.item(i,3).value  = b.Tolerance.Lower*10
'	GoExcel.Save()
	Next
oWB.close
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 36
eladm
you do most of the job 🙂
why we need this :
Message 16 of 36
bradeneuropeArthur
That is the template!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 36
bradeneuropeArthur
'Dim oXLFile As String = "C:\TEMP\DrawingDimensions.xlsx"
Dim oWB As Microsoft.Office.Interop.Excel.Workbook = oExcel.Workbooks.add
	i = i + 1
'	GoExcel.Save()
	Next
oWB.close
Without template use this:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 36
eladm
The symmetric still make problem
Message 19 of 36
eladm
Hi
Can you fix the code ? It not export the symmetric tolerance value for min. and max. , only one of them
best regards
Message 20 of 36
bradeneuropeArthur
Sure:
Dim oWB As Microsoft.Office.Interop.Excel.Workbook = oExcel.Workbooks.add'.Open(oXLFile)
'oCells.item(2,1).value= b.Text.Text.ToString
	i = i + 1
'MsgBox (b.Text.Text & " " & b.Tolerance.ToleranceType)
	If b.Tolerance.ToleranceType = 31236 Then
If b.Tolerance.ToleranceType = 31233 Then
If b.Tolerance.ToleranceType = 31235 Then
		oCells.item(i,2).value = "+/-" & b.Tolerance.Upper*10
		'oCells.item(i,3).value  = "+/-" &b.Tolerance.Lower*10.ToString
	Next
oWB.close
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
