find what the density is ?
Darkforce_the_ilogic_guy
Advisor Advisor
I  want to find a way to find the density of all the part. and paint the part ....
I have the code for paint the part ... now I need to find out if i can find out with componemt that need to get paited
can I use this for each loop to finde it?  can anyone tell me how to do it with it ... code below does not work ..but believe it is very to to what i need
Dim oAsmDoc As AssemblyDocument
	oAsmDoc = ThisApplication.ActiveDocument
Dim oRefDocs As DocumentsEnumerator
	oRefDocs = oAsmDoc.AllReferencedDocuments
	Dim oRefDoc As Document
	For Each oRefDoc In oRefDocs
D = oRefDoc.PhysicalPropertiesAsset.item("density")
MsgBox(D)
next
bradeneuropeArthur
Hi @Darkforce_the_ilogic_guy
Based on what value needs it to be painted?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
1 . which as a rule is because the user has forgotten to give the componemt  it proper weight
bradeneuropeArthur
D = oRefDoc.PropertySets.Item(3).item("density").value
MsgBox(D)
next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
