MyFirstInventorPlug-in errors
johan.degreef
Advisor Advisor
Message 1 of 15
johan.degreef
Am tryng to complete lesson 3 in MyFirst Inventor plugin
just copied the code from the lesson, but get several errors.
Does anybody have an idea what is wrong?
Imports System
Imports System.Type
Imports System.Activator
Imports System.Runtime.InteropServices
Imports Inventor
Public Class Form1
    Dim _invApp As Inventor.Application
    Dim _started As Boolean = False
    Public Sub New()
        ' This call is required by the designer.
        InitializeComponent()
        ' Add any initialization after the InitializeComponent() call.
        Try
            _invApp = Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
            Try
                Dim invAppType As Type =
                GetTypeFromProgID("Inventor.Application")
                _invApp = CreateInstance(invAppType)
                _invApp.Visible = True
                _started = True
            Catch ex2 As Exception
                MsgBox(ex2.ToString())
                MsgBox("Unable to get or start Inventor")
            End Try
        End Try
    End Sub
    Private Sub Form1_FormClosed(ByVal sender As Object, ByVal e As System.Windows.Forms.FormClosedEventArgs) Handles Me.FormClosed
        '  This will shut down the Inventor session started when the form was started
        If _started Then
            _invApp.Quit()
        _invApp = Nothing
    End Sub
End Class
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Replies (14)
Message 2 of 15
bradeneuropeArthur
Hi Johan,
Have you all references set? Via project properties //references.
What framework are you using?
Let us clarify this per mail if you are fine?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 15
etaCAD
To get rid of the first error please set a reference to Sytem.Runtime.InteropServices.
For both other errors I recommend to replace "MsgBox..." by "MessageBox.Show(...)" and add "Imports System.Windows.Forms" on top of your code. MsgBox is from old VB6.
You can also place your mouse pointer on the error in the code window, wait for the tooltip and have a look what VS proposes how to fix this issue.
Andreas
etaCAD
Message 4 of 15
bradeneuropeArthur
Hi @johan.degreef
With these references set it should work:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 15
johan.degreef
Still som errors
Message 6 of 15
bradeneuropeArthur
can you show me the references dialog again?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 15
johan.degreef
Message 8 of 15
johan.degreef
But if I start a new project what should I select?
Message 9 of 15
bradeneuropeArthur
For an Add In and you should select "Autodesk Inventor 2021 VB Addin".
For a standalone app like your first code you need different for example a Windows Form.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 15
johan.degreef
Can you see which template is used in an existing project?
If I create a new Windows Form project I cannot use 4.7.1 . NET, which seems to be the correct one?
Message 11 of 15
bradeneuropeArthur
What version of Visual studio are you using?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 15
johan.degreef
@bradeneuropeArthur
Visual Studio Community2019
Message 13 of 15
bradeneuropeArthur
That could be to heigh for inventor 2021.
Vs2017 may better.
I will check for you ASAP.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 15
bradeneuropeArthur
Should be OK.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/What-...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 15
johan.degreef
Uninstalled 2019, installed 2017, done the same excercise, and it all works...
