execute ILogic for all open documents
philip.G
Message 1 of 21
philip.G
Hey There
I was wondering.
Is there a way to execute an I-Logic - script for all open documents? (eg. in a for-loop)
I know there is something similar for all referenced documents of an assembly but couldn't find it for all open files.
I need this because I want to execute an I Logic code in a bunch of drawings but these drawings aren't all in the same assembly. (And I don't want to make an assembly just for executing this script.)
Thanks for your suggestions.
Best Regards
Replies (20)
Message 2 of 21
This is in VBA but can probably be adapted to iLogic:
    Dim oDoc As Document
    For Each oDoc In ThisApplication.Documents.VisibleDocuments
        If oDoc.DocumentType = kDrawingDocumentObject Then
    Next oDoc
Message 3 of 21
bradeneuropeArthur
The following code does this for you:
Public Sub Start()
Dim a As Application
Set a = ThisApplication
Dim b As Document
Dim c As Documents
For Each b In a.Documents.VisibleDocuments
RuniLogic "MyRule1", b
Next
End Sub
Public Sub RuniLogic(ByVal RuleName As String, ByVal oDoc As Document)
  Dim iLogicAuto As Object
  If oDoc Is Nothing Then
    MsgBox "Missing Inventor Document"
    Exit Sub
  Set iLogicAuto = GetiLogicAddin(ThisApplication)
  If (iLogicAuto Is Nothing) Then Exit Sub
  iLogicAuto.RunExternalRule oDoc, RuleName
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
  Dim addIns As ApplicationAddIns
  Set addIns = oApplication.ApplicationAddIns
  Dim addIn As ApplicationAddIn
  Dim customAddIn As ApplicationAddIn
  For Each addIn In addIns
    If (addIn.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then
      Set customAddIn = addIn
    Exit For
  Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 21
philip.G
Thanks for the idea, I will check tomorrow!
Message 5 of 21
philip.G
wow, this didn't took long for a second answer.
I will definitely check if these lines of code work!
Message 6 of 21
bradeneuropeArthur
what do you mean...?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 21
bradeneuropeArthur
It Works?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 21
philip.G
I tried both I logic an vba. neither worked.
I'm not sure what the fault is,
maybee it's just formatting. I will check again in about an hour when I'm at the cad workplace again.
One of the errors i got was that "set" isn't supportet anymore...
But your code seems reasonable to me. I don't think that is were the error occured.
Message 9 of 21
philip.G
It worked with the code below from @Anonymous
But I don't know how to call the I Logic with this code.
Public Sub Multi_Ilogic()
            MsgBox ("It works! OMG!!!")
            -> how do I call an I Logic from the vba-editor?
    Next oDoc
End Sub
then I tried @bradeneuropeArthur code.
Now it worked as well. (My fault, messed it up with Ilogic/vba window ;-J)
But...
nothing happend.
I inserted some Message-boxes to check if the code made it to the essential parts. And it did. No Problems whatsoever.
But the Test-Ilogic Script wasn't executed.
The Ilogic-Text-script works. I'm 100% certain. (Its just a messagebox telling me that it works.)
I used the code below. I hope someone knows better than me Smiley Wink
Best regards
Public Sub Multi_Ilogic_2()
'MsgBox "Dim,Set application succesful"
Dim b As Document
Dim c As Documents
'MsgBox "Dim,Set document succesful"
RuniLogic "Test", b
MsgBox "run succesful"
Next
End Sub
   'Else
    'MsgBox "Inventor document not missing"
    Exit Sub
End Sub
      'MsgBox "Set customAddIn = addIn"
    Exit For
  Next
End Function
Message 10 of 21
bradeneuropeArthur
How is your external rule named: is it Test.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 21
philip.G
exactly
Message 12 of 21
bradeneuropeArthur
Can you share that too
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 21
philip.G
'MsgBox "OMG It worked!!!"
Message 14 of 21
bradeneuropeArthur
iLogicAuto.RunExternalRule oDoc, RuleName End Sub
You try to run external rule. But it is s document rule
Change to
iLogicAuto.RunRule oDoc, RuleName End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 21
philip.G
End Sub
now it looks like this. but still, no success.
Is maybee the varaible RuleName defined wrong?
Message 16 of 21
bradeneuropeArthur
iLogicVb.RunRule(“componentName”, “ruleName”)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 21
philip.G
then i put in :?
iLogicVb.RunRule(“Rule”, “Test”)
Message 18 of 21
bradeneuropeArthur
Complete new:
And it works for me
Public Sub Internal_iLogic()
Set addIns = ThisApplication.ApplicationAddIns
        If InStr(addIn.DisplayName, "iLogic") > 0 Then
                        addIn.Activate
            Set iLogicAuto = addIn.Automation
            Exit For
    Next
  'Set oDoc = ThisApplication.ActiveDocument
    Exit Sub
iLogicAuto.RunRule oDoc, "Test" 'for internal rule
'iLogicAuto.RunExternalRule oDoc, "Test" 'for external rule
'oDoc.Activate
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 21
philip.G
Hi @bradeneuropeArthur
I changed the code just a touch. now it works for me too!
Thanks a lot for your help. I could have never done this without you.
Below the code I use now.
Have a nice day ☺
                        addIn.Activate
            Exit For
    Next
    Exit Sub
    'Else:
        'iLogicAuto.RunRule oDoc, "Test"
'oDoc.Activate
Next
End Sub
Message 20 of 21
bradeneuropeArthur
Your thanks are appreciated.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
