execute ILogic for all open documents
philip.G
Message 1 of 21
philip.G
Hey There
I was wondering.
Is there a way to execute an I-Logic - script for all open documents? (eg. in a for-loop)
I know there is something similar for all referenced documents of an assembly but couldn't find it for all open files.
I need this because I want to execute an I Logic code in a bunch of drawings but these drawings aren't all in the same assembly. (And I don't want to make an assembly just for executing this script.)
Thanks for your suggestions.
Best Regards
Replies (20)
Message 21 of 21
benedikt.fecke6ZXRX
Observer
Observer
Hello everyone,
I want to have iproperties placed in all open documents. I tried out the code above but it doesn't work. The message says that "set" operations are no longer supported.
I have this but it doesn't go over to all open documents:
Dim i As Byte
Dim namingarraylist(3) As String
Dim oDoc As Document
namingarraylist(0) = "test1"
namingarraylist(1) = "test2"
namingarraylist(2) = "test3"
For Each oDoc In ThisApplication.Documents.VisibleDocuments
oDoc.Activate
oCustomPropertySet = ThisApplication.ActiveDocument.PropertySets.Item("Inventor User Defined Properties")
For i = 0 To UBound(namingarraylist) -1
	iProperties.Value("Custom", namingarraylist(i)) = ""
Next i
For Each oCustProp In oCustomPropertySet
	'check property name against the list you don't want to delete
	If namingarraylist.Contains(oCustProp.name)Then
		'skip it
	Else
		'delete the custom iProperty
		oCustProp.Delete
Next
'    End If
Next oDoc
Any ideas?
