Get path of parent folder
Is there a way to get the parent path for the current file? I know how to get the current path for the open model using iLogic, but I want to only get the path to the parent (E.g. File is in c:\folder1\folder 2\file.asd, and I want iLogic to return only c:\folder 1)
philip.G
It isn't really the answer you are looking for, but I would just manipulate the path inside the script. 😛
bradeneuropeArthur
Dim a As New System.IO.DirectoryInfo("D:\Test\Old")
        a.GetDirectories()
        MsgBox(a.Parent.Name)
Dim fio As New System.IO.FileInfo("c:\folder1\folder 2\file.asd")
        MsgBox(fio.DirectoryName)
        Dim a As New System.IO.DirectoryInfo(fio.DirectoryName)
        a.GetDirectories()
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Perfect! Thanks
bradeneuropeArthur
Your thanks are appreciated, and my pleasure to help you...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
