Error ilogic - Recognize bendings
Message 1 of 23
I use the ilogic code below to recognize if there are bendings in a sheet metal file.
The result is put in a costum iproperty (Bend exist /  No bend exist.
The code does what it has to do..
Public Sub Main()
Dim a As Inventor.Application
a = ThisApplication
Dim b As PartDocument
 b = a.ActiveDocument
'Dim b As Inventor.Document
'b= thisdoc.document
Dim sm As SheetMetalComponentDefinition
sm = b.ComponentDefinition
MsgBox (sm.Bends.Count)
Dim customProp As Inventor.Property
On Error Resume Next
customProp = b.PropertySets.Item(4).Add("Bend Exist", "Bending")
If Err.Description Then
	Err.Clear
customProp = b.PropertySets.Item(4).Item("Bending")
If sm.Bends.Count > 0 Then
customProp.Value = "Bend Exist"
Else If sm.Bends.Count = 0 Then
customProp.Value = "No Bend Exist"
End Sub
But I get the following error message while saving a assembly with a sheet metal file.
Is there anyone who can help me to solve this?
Error in rule: Bending, in document: 24783.ipt
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: Interface wordt niet ondersteund (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Thank you in advance!
Jeffrey
Replies (22)
Message 2 of 23
Sergio.D.Suárez
Hi, if you apply this rule in a sheet file and it works, check the line that says
  "b = a.ActiveDocument"
If you came to place events before saving the part, and you have opened an assembly and you save everything, the active document in this case is the assembly and you may get the error for that reason. Try changing by this other line
"b = ThisDoc.Document"
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 23
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Please provide sample assembly file with sheet metal parts (make sure that files are non confidential) and steps to reproduce issue.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 23
@chandra.shekar.g
Please find attach an sample file (pack en go).
The problem arises only once!
To simulate the problem you must make a change in the sheet metal file and then save the assembly again.
When the assembly is saved it will not happen again until a change is made in the sheet metal file.
@Sergio.D.Suárez Unfortunately this does not help.
Thanks for the help 😉
Jeffrey
Message 5 of 23
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Change iLogic code like below. It make sure that document is sheet metal document.
Public Sub Main()
	a = ThisApplication
	Dim doc = ThisDoc.Document
	If doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			Err.Clear
	Else
		Exit Sub
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 23
Sergio.D.Suárez
Make these changes and I find Inv 2018, please watch the video
what inventor's version do you have?
Public Sub Main()
a = ThisApplication
	Err.Clear
End Sub
Mechanical Designer
Message 7 of 23
bradeneuropeArthur
I know that piece of code, ha ha....
Smiley Happy
Is it working now or shall I send you an update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 8 of 23
@chandra.shekar.g
I receive new errors whit this code. But thanks your help!
@Sergio.D.Suárez
@bradeneuropeArthur
If I use you code everything works perfectly except for one thing.
When saving the template file I get an error.. (see pictures below).
But if I just save the template and use it then it works well.
Should this still be resolved or is this error innocent?
I truly appreciate your time and effort
Jeffrey
Message 9 of 23
bradeneuropeArthur
You talk about the code above here ONLY?
Or is there more code in your file?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 23
@bradeneuropeArthur
The ilogic code from @Sergio.D.Suárez is the only code in the template.
Jeffrey
Message 11 of 23
bradeneuropeArthur
I will give it a short test/look.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 23
bradeneuropeArthur
is the template a "sheet metal part" or a "normal part"?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 23
@bradeneuropeArthur
It's a sheet metal template..
Jeffrey
Message 14 of 23
bradeneuropeArthur
Are you running the code above "on save"?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 23
Before save document (please see picture below.)
Jeffrey
Message 16 of 23
Sergio.D.Suárez
hi how are you, a small detail, have you noticed that the initial files that you have shared are read only? in the video modify this because otherwise it does not allow me to save the files, maybe it can give you problems if one is reading and the other is not.
Mechanical Designer
Message 17 of 23
@Sergio.D.Suárez
Very good and how are you?
I think this is because I use vault professional..
Jeffrey
Message 18 of 23
bradeneuropeArthur
Do you have permission to write and edit the template file in the specific directory (Template Directory)?
Because the file wants to write on save.
better is to trigger if the file requires a update and not to run it always on save if not necessary!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 23
Ì have permission two write the file in the template direction.
I check the file out and then I have write permission.
Okay, but that wil not solve the error which I get while saving the template?
perhaps I can change the event trigger to: Part geometry change?
Jeffrey
Message 20 of 23
bradeneuropeArthur
I am investigating the issue.
For me the code runs fine!
For my understanding:
The template file location is a vault workspace location, right?
Is the location in the workspace directory or outside the workspace directory?
Seems to have to do with the permissions of vault security or directory security.
Could you make a screenshot of your vault browser with the Project directory and the template directory/
Are you able to save the file anywhere else with succes or not?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
