Save As and Autonumbering with ilogic
We are about to change to using a vault autonumbering system, and i'm wanting this to work when i'm using the "SaveAs" command in my ilogic code. My Autonumbering system is simply SA-12345 (sequential), so there are no further user options/inputs necessary.
Is there a way where i can just navigate to the save location, but still get the autonumbering to populate the file name?
I am going to want to do this with multiple files in an assembly. These will all reside in the same folder, so ideally i would just browse to the folder once, and then ilogic does the rest. I don't want to have to click "OK" for every individual file.
Regards
Mark
bradeneuropeArthur
With vault you can use datastandard for this. You don't need I logic for that.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
I'm already using ilogic to do other things. I am not using ilogic to solely to autonumber...
I am using datastandard. I want this to work alongside my ilogic code
