Error ilogic - Recognize bendings
Message 1 of 23
I use the ilogic code below to recognize if there are bendings in a sheet metal file.
The result is put in a costum iproperty (Bend exist /  No bend exist.
The code does what it has to do..
Public Sub Main()
Dim a As Inventor.Application
a = ThisApplication
Dim b As PartDocument
 b = a.ActiveDocument
'Dim b As Inventor.Document
'b= thisdoc.document
Dim sm As SheetMetalComponentDefinition
sm = b.ComponentDefinition
MsgBox (sm.Bends.Count)
Dim customProp As Inventor.Property
On Error Resume Next
customProp = b.PropertySets.Item(4).Add("Bend Exist", "Bending")
If Err.Description Then
	Err.Clear
customProp = b.PropertySets.Item(4).Item("Bending")
If sm.Bends.Count > 0 Then
customProp.Value = "Bend Exist"
Else If sm.Bends.Count = 0 Then
customProp.Value = "No Bend Exist"
End Sub
But I get the following error message while saving a assembly with a sheet metal file.
Is there anyone who can help me to solve this?
Error in rule: Bending, in document: 24783.ipt
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: Interface wordt niet ondersteund (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Thank you in advance!
Jeffrey
Replies (22)
Message 21 of 23
Sergio.D.Suárez
As it says @bradeneuropeArthur  tries to activate the rule with any change of parameter of the model or any change of geometry of the part
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 22 of 23
nisse
I accidentally sent this message from other accounts.
Message 23 of 23
This time from the right account.
Please find below a printscreen of the structure.
@bradeneuropeArthur
I'll get the same error when I save the template in de design directory..
Jeffrey
