iLogic: turn off ambient shadow if filesize of open file is bigger then XXX
Neuzzo
Neuzzo
Hi all, i'm newbie of iLogic code and if is possible i need an help  with this code:
Dim doc As Document
doc = ThisApplication.ActiveDocument
Dim ls As AppAmbientShadowCmd
Dim myFile As New FileInfo(ThisDoc.PathAndFileName(True))
Dim sizeInBytes As Long = myFile.Length
Dim sizeInKB As Long = sizeInBytes / 1024
Dim sizeInMB As Long = sizeInKB / 1024
If sizeInMB > 45
	AppAmbientShadowCmd(False)
Else AppAmbientShadowCmd(True)
This is what i want to do:
When i open an assembly or part, if filesize is bigger then 45MB, ilogic shut down ambient shadow.
Else put the shadow on.
Any help is really apreciated.
Danilo "DannyGi" G.
Mechanical design engineer and product developer
Thomas_Savage
Hello @Neuzzo
This post would be better in the inventor customization forum.
I have asked this to be moved for you.
Hope you find your answer there.
Thomas.
Thomas Savage
Design Engineer
Neuzzo
Thank you and sorry for wrong place
Danilo "DannyGi" G.
lmc.engineering
Hi @Neuzzo
You were close!
This is what you need:
Imports System.IO
Dim oView As Inventor.View = ThisApplication.ActiveView
If sizeInMB > 45 Then
	oView.ShowAmbientShadows = False
Else
	oView.ShowAmbientShadows = True
Neuzzo
@lmc.engineering wrote:
Hi @Neuzzo
You were close!
Imports System.IO
Else
Omg you're the man! Thank you
Danilo "DannyGi" G.
