Controlling Arrowheads on Drawing Dimensions with VBA
204Е10
204Е10
Hi everyone,
can help me someone to find how to create ilogic rule to control the arrowhead on chain dimensions, sometime this misleading people on drawings.
I have found the property to chain but really I don't know to create the routine.
Thanks.
Note.
DimensionStyle.ArrowheadTypeForChainDimensions() As ArrowheadTypeEnum
Name
Value
Description
kFilledArrowheadType
71941
Filled arrowhead.
Examples for other use of arrowhead.
https://forums.autodesk.com/t5/inventor-customization/controlling-arrowheads-on-drawing-dimensions-w...
https://forums.autodesk.com/t5/inventor-customization/adding-holethreadnote-to-correct-side-of-hole-...
YuhanZhang
Here is iLogic code sample, in UI you select a chain dimension, and run the iLogic code in a rule:
Sub Main()
	Dim oDoc As DrawingDocument
	oDoc = ThisDoc.Document
	On Error Resume Next
	Dim oChainDim As LinearGeneralDimension
	oChainDim = oDoc.SelectSet(1)
	oChainDim.FirstArrowheadType = ArrowheadTypeEnum.kFilledArrowheadType
	oChainDim.SecondArrowheadType= ArrowheadTypeEnum.kFilledArrowheadType
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
204Е10
How I can applicate this rule in every section of the chain without pick one by one?
Like set on the Edit Dimensions Style>Display>Termantor>Intermal chain terminator> Filled
Many thanks for you time and help.
YuhanZhang
The API for changing the terminator in the dimension style is not available yet, but you can use the iLogic to batch changing the arrowhead of all the linear dimensinos like below:
Sub Main()
	Dim oSheet As Sheet
	oSheet = oDoc.ActiveSheet
	Dim oLinearDim As LinearGeneralDimension
	Dim oDim As GeneralDimension
	For Each oDim In oSheet.DrawingDimensions.GeneralDimensions
		If oDim.Type = ObjectTypeEnum.kLinearGeneralDimensionObject Then
			oLinearDim = oDim
			oLinearDim.FirstArrowheadType = ArrowheadTypeEnum.kFilledArrowheadType
			oLinearDim.SecondArrowheadType = ArrowheadTypeEnum.kFilledArrowheadType
	Next
End Sub
Just run the rule and it will update all the linear dimensions' arrowhead on the active sheet. Hope this helps.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
204Е10
Thanks it run perfectly.
