Searching subfolders and selecting them using Ilogic (TopNode/Enumerator issue)
j.t.a.tebraake
j.t.a.tebraake
Hello everyone
First post, so im hoping this is the right place.
What im trying to do: For a large assembly template with multiple configurations im trying to supress different subfolders based on the product code that is given to IV (Ilogic).
My brick wall: I cant seem to figure out how to cycle through subfolders. I know i can select folders that are "on top" using something like:
oApp = ThisApplication
oDoc = oApp.ActiveDocument
oPane = oDoc.BrowserPanes("Model")
oTopNode = oPane.TopNode
oSelectSet = oDoc.SelectSet
oSelectSet.Clear
oSelectSet.Select(oTopNode.BrowserFolders.Item("folder_level1"))
But since it will only look thought my topnodes it wont select a "folder_level2".
So i think i need some sort of traverse function that will:
-Open a top level folder
-Get all the nodes in that folder
-See if one of those nodes is a folder
-use that node to rinse and repeat.
according to inventor knowledgedesk:
BrowserFolders
Property that returns a collection of all browser folders contained directly under this node in the browser.
BrowserNodes
Property that returns a collection of the top level BrowserNode objects contained under this node.
so i figured i coould just do someting like: TopNode.BrowserFolders.BrowserNodes.BrowserFolders.BrowserNodes.Browserfolders.Item("folder_level3")
But it doesnt work like that since the BrowserFolders function returns a BrowserFolderEnumerator.
So any help on how to get from the BrowserFolderEnumerator to the node of the subfolder (i think that is the step to be taken) would be greatly appreciated
Inventor 2016
P.S. only help i could find on the forums was either top level or would involve the occurences in a subfolder, but i need the folder specifically
bradeneuropeArthur
This would help you:
for VBA and Vb.net
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim c As BrowserPane
Set c = a.ActiveDocument.BrowserPanes.ActivePane
Dim d As BrowserNode
Set d = c.TopNode
Dim d1 As BrowserNode
Dim f As BrowserFolder
'MsgBox d.FullPath
For Each d1 In d.BrowserNodes
MsgBox d1.FullPath
Next
For Each f In d.BrowserFolders
MsgBox f.Name
Next
End Sub
For I logic
Public Sub main()
a = ThisApplication
d = c.TopNode
'MsgBox d.FullPath
MsgBox d1.FullPath
Next
MsgBox f.Name
Next
End Sub
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
And now with selecting them:
Public Sub main()
Set d = c.TopNode
'MsgBox d.FullPath
MsgBox d1.FullPath
Next
Dim se As SelectSet
Set se = a.ActiveDocument.SelectSet
se.Select f
MsgBox f.Name
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
j.t.a.tebraake
thanks for the input. But i would like to ask you to elaborate on this programs function.
I ran the code on a small testfile and it selects all the top level folders. If i understand correctly:
-d is the top level nodes
-d1 the nodes one level deeper  ( For Each d1 In d.BrowserNodes)
however   "  MsgBox d1.FullPath   "   only returns the top level nodes and ignores the other levels.
so i guess im missing something
bradeneuropeArthur
Will come back on this asap.
I am far from my desk right now...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
j.t.a.tebraake
Ah i found what i was missing. I blatantly assumed that the first row of folders was the top level. (it is like that in the select.TopNode ilogic code i posted). but the assembly itself is the top level. So what you posted does work.
Public Sub main()
Set d = c.TopNode
Dim d2 As BrowserNode
'MsgBox d.FullPath
'MsgBox d1.FullPath
For Each d2 In d1.BrowserNodes
MsgBox d2.FullPath
Next
Dim se As SelectSet
se.Select f
MsgBox f.Name
Next
Next
End Sub
