Parameter to be used in iLogic rule
I'm trying to work with a user parameter in a rule.
The parameter is called HolesRequired and is set to 1 ul default.
When this changes, I want it to influence the model parameters. I'm new to Rules so any help here would be appreciated.
Sergio.D.Suárez
Hi, The units of the parameters must be specified in the parameter table, taking care that there is no conflict in the units used
So if you need that rule, it's
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
