renumber partlist
renumber partlist
GeorgK
Advisor Advisor
renumber partlist
GeorgK
Hello together,
I got a program to renumber the partlist. This is working great but not always.
https://forums.autodesk.com/t5/inventor-customization/renumber-partlist/td-p/5300783
When I have a renumbered part list like this:
and renumber the number from 11 to 14 to 1 to 4  I get this:
How could I fix this?
Thank you Georg
DRoam
I think you have to enter the ROW numbers that you want to renumber, not the Item numbers. It looks like you're entering "11-14", so it's renumbering ROWS 11-14 (Item No. 206-209).
Item No. 11-14 are in rows 1-4. So your inputs should be:
Start Row = 1
End Row = 4
Start Value = 1
Step Value = 1
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK ,
@DRoam seems to be correct.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
GeorgK
@chandra.shekar.g , @DRoam
I had the problem that it does not renumber the partlist the correct way, when I renumber it several times.
DRoam
@GeorgK, what do you mean? Can you give an example?
GeorgK
I saved the drawing between. That solved the problem.
