Error during saving drawing containing iLogic
Message 1 of 10
Since our company made the exchange to Inventor 2018, a lot of errors occured. One of the errors is this one:
I'm just a junior engineer, so I am not experienced with errors. Also my collegues don't know where these errors come from. The only thing we know for sure is that there is something wrong in the iLogic rules. The iLogic rules are as follow:
ActiveSheet = ThisDrawing.Sheet("Sheet:3")
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_1")=0 Then
ActiveSheet.View("VIEW 1").View.Suppressed=True
ActiveSheet.View("VIEW 1A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 1").View.Suppressed=False
ActiveSheet.View("VIEW 1A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_2")=0 Then
ActiveSheet.View("VIEW 2").View.Suppressed=True
ActiveSheet.View("VIEW 2A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 2").View.Suppressed=False
ActiveSheet.View("VIEW 2A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_3")=0 Then
ActiveSheet.View("VIEW 3").View.Suppressed=True
ActiveSheet.View("VIEW 3A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 3").View.Suppressed=False
ActiveSheet.View("VIEW 3A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_4")=0 Then
ActiveSheet.View("VIEW 4").View.Suppressed=True
ActiveSheet.View("VIEW 4A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 4").View.Suppressed=False
ActiveSheet.View("VIEW 4A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_5")=0 Then
ActiveSheet.View("VIEW 5").View.Suppressed=True
ActiveSheet.View("VIEW 5A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 5").View.Suppressed=False
ActiveSheet.View("VIEW 5A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_6")=0 Then
ActiveSheet.View("VIEW 6").View.Suppressed=True
ActiveSheet.View("VIEW 6A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 6").View.Suppressed=False
ActiveSheet.View("VIEW 6A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_7")=0 Then
ActiveSheet.View("VIEW 7").View.Suppressed=True
ActiveSheet.View("VIEW 7A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 7").View.Suppressed=False
ActiveSheet.View("VIEW 7A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_8")=0 Then
ActiveSheet.View("VIEW 8").View.Suppressed=True
ActiveSheet.View("VIEW 8A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 8").View.Suppressed=False
ActiveSheet.View("VIEW 8A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_9")=0 Then
ActiveSheet.View("VIEW 9").View.Suppressed=True
ActiveSheet.View("VIEW 9A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 9").View.Suppressed=False
ActiveSheet.View("VIEW 9A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_10")=0 Then
ActiveSheet.View("VIEW 10").View.Suppressed=True
ActiveSheet.View("VIEW 10A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 10").View.Suppressed=False
ActiveSheet.View("VIEW 10A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_11")=0 Then
ActiveSheet.View("VIEW 11").View.Suppressed=True
ActiveSheet.View("VIEW 11A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 11").View.Suppressed=False
ActiveSheet.View("VIEW 11A").View.Suppressed=False
If Parameter("400-02CW1-47-D2-SS.iam.X_FLOORLEG_12")=0 Then
ActiveSheet.View("VIEW 12").View.Suppressed=True
ActiveSheet.View("VIEW 12A").View.Suppressed=True
Else
ActiveSheet.View("VIEW 12").View.Suppressed=False
ActiveSheet.View("VIEW 12A").View.Suppressed=False
In this case, the assembly is called "400-02CW1-47-D2-SS.iam". As we copy the assembly multipile times and use therefore different floorbeams, we suppress some of the floorbeams. If they are suppressed in the assembly, we won't have them on the drawing.
Sheet 1 and 2 contains global information of the position of the floorbeams, sheet 3 contains the sizes of the parts of every individual floorbeam.
If I run this code while in sheet 3, the error only occurs 1 time and I'm able to continue my work. However, if I run this code while I'm in sheet 2, the error occurs a lot of times. (Today I had to make an construcion on my keyboard so I didn't have to press the enter-button all the time by myself, after 30 minutes I had to close Inventor using task manager.)
The question is, what is the reason that the error occurs and how can we fix this?
Replies (9)
Message 2 of 10
Thomas_Savage
Hello @Anonymous
The link below is for Inventor Customization.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
This forum is for iLogic.
You will be better posting here. So experts can help you solve your problem.
Thomas.
Thomas Savage
Design Engineer
Message 3 of 10
Mark.Lancaster
@Anonymous
I've requested for your posting to be relocated to the Inventor Customization forum.
@Thomas_Savage
For the future you can just request that using the report button..  Smiley Wink
Mark Lancaster
Message 4 of 10
Thomas_Savage
@Mark.Lancaster Thank you.
I didn't know that.
Will use the report button next time.
Thomas.
Thomas Savage
Design Engineer
Message 5 of 10
MechMachineMan
Where is this rule located? In a drawing template?
Also, in the drawing parameters, is there really a parameter named "
and so on?
At a glance, it looks like the rule might have had some quotation marks and a comma deleted, but I can't be sure.
Also, is the model that has the floor beams and such simply 'pack-and-go'ed for each project, or do you reference the same frame for all projects from a library?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 6 of 10
MechMachineMan
Here is some samples and how it works. I have verified it works for a part of the corresponding name and the existence of parameters, sheet names, view names of that in the code.
Possible reasons your code isn't working:
1. The sheet names in the document doesn't match the sheet name in the code.
2. The parameter doesn't match the name of a DRAWING parameter if it is supposed to be the drawing parameter referenced. These parameters are different from part parameters.
3. The parameter has had the quotation marks and a comma deleted in it, in the case it actually is supposed to refer to the model parameter.
4. Your view names do not match those in the code.
'This grabs the sheet with the exposed sheet name "Sheet:1".
'It will not work properly if you revise the sheet name
'The below line is always to be active
ActiveSheet = ThisDrawing.Sheet("Sheet:1")
''param1 is a drawing parameter
'If Parameter("param1")=True Then
'   '"VIEW1" etc are the ACTUAL names of the view. It will not work as expected if view names have been changed
'	ActiveSheet.View("VIEW1").View.Suppressed=True
'	ActiveSheet.View("VIEW2").View.Suppressed = False
'Else
'	ActiveSheet.View("VIEW2").View.Suppressed=True
'	ActiveSheet.View("VIEW1").View.Suppressed = False
'End If
'If above is uncommeneted, comment the below code out and vice versa.
'part1.ipt is the FILE NAME of the part in the drawing
'PartParam is the parameter name of of a parameter in the part
If Parameter("Part1.ipt", "PartParam")= True Then
	ActiveSheet.View("VIEW1").View.Suppressed = True
	ActiveSheet.View("VIEW2").View.Suppressed = True
Else
Justin K
Message 7 of 10
MechMachineMan
Try this line and see if it works. If it does, we know the parameters have comma/quotes missing.
errfound = false
Dim int as Integer
int = Parameter("400-02CW1-47-D2-SS.iam", "X_FLOORLEG_1")
MsgBox(int & vblf & vblf & "It would appear the parameter is intended for the assembly, instead of the drawing as your forum code has it written")
Try
If int=0 Then
Else
Catch
MsgBox("Error found with view names!")
errfound = True
End try
If errfound = False
MsgBox("Rule ran without error!")
End if
Justin K
Message 8 of 10
bradeneuropeArthur
In general there need to be used comma' s
This is the method be used:
If Parameter("400-02CW1-47-D2-SS.iam    ,       X_FLOORLEG_2")=0 Then
This is in all cases wrong....
You wrote like below:
If Parameter("400-02CW1-47-D2-SS.iam    .        X_FLOORLEG_2")=0 Then
If you have any questions regarding this, please let me know.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 9 of 10
johnsonshiue
Hi! Is the assembly of interest here located in a Library folder? If yes, this is known change in 2018. Inventor API no longer allows you to overwrite a library component. There are two ways to resolve the issue. You can either create a new project which allow you to edit the library components or set an application property (as of 2018.2 update).
Many thanks!
Software Test Engineer
Message 10 of 10
Thank you! This code helped me a lot! It was indeed the comma/quotes problem.
