Creat List of idw Layers using iLogic
Hello All,
I'm hoping this is an easy question & just something I'm overlooking.
I have the following code
'get single layer
Dim odoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oBaseLayer As Layer
oBaseLayer = odoc.StylesManager.Layers.Item("DWG__TXT50")
'change color To red
Dim oColor As Color
oColor = oBaseLayer.Color
oColor.Red = 0
oColor.Green = 0
oColor.Blue = 0
oBaseLayer.Color = oColor
This code will find the layer "DWG__TXT50" & change its color to Black which is great.
I want to ad an "IF" statement to this so that the code will search all Layers within idw that have in string "DWG" & change all those layers colors to Black.
For some reason I cannot find any code/api to get idw layers in an item list to interrogate them.
PLEASE HELP!! lol
Many Thanks in advance
Tim
bradeneuropeArthur
'oBaseLayer = odoc.StylesManager.Layers.Item("DWG__TXT50") 'change color To red
For each oBaselayer in odoc.stylemanager.layers
Dim oColor As Color
oColor.Red = 0
oColor.Green = 0
oColor.Blue = 0
Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
HermJan.Otterman
Hallo Tim,
here is a bit of code...
 Dim LayerCollection As LayersEnumerator = thisdoc.Document.StylesManager.Layers
        Dim Layer As Layer
        'loop through LayerCollection
        For Each Layer In LayerCollection
            'assumption If DWG is in the name then alway the first 3 letters!
            Dim layerName As String = Layer.Name
            Dim first3Letters As String = Strings.Left(layerName, 3)
            If first3Letters = "DWG" Then
                'change color
                'Color Black
                Dim oColor As Color = Layer.Color
                oColor.Red = 0
                oColor.Green = 0
                oColor.Blue = 0
        Next
 it goes through every layer, checking the first three letters. if they are "DWG" then the color will be black
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Excellent!!! Worked a treat.
Thanks Herm Jan much appreciated
Kind Regards
Tim
