Din 61 Thread
Din 61 Thread
Din 61 Thread
Hi All,
First time poster. I want to apply a Din 61 thread to a plastic bottle cap I'm designing. It is a very common thread for European water tanks/ chemical drums etc. It appears Inventor does not have this thread standard. Is there an add-in with additional threads, a users extended thread file, or someone who knows the thread pattern that I can use? There seems to be very limited information regarding the DIN 61 standard in terms of technical/ engineering specifications. I could even just create a coil pattern and cut extrude if I knew the sketch dimensions.
Thank you.
bradeneuropeArthur
You could try to add this to the Excel Table with threads within Inventor!
Found in the Design data folder...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Read this how:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Inve...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thanks Braden,
I would like to use this method but I need the data to populate the file. I currently do not have access to the Din 61 specification data.
bradeneuropeArthur
Read this:
https://www.buerkle.de/en/knowhow/about-threads
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
There doesn't appear to be a DIN 61 standard on the din.de website so now I'm curious what standard DIN 61 falls under.
Perhaps The DIN 13 family?
DIN 13-01:
ISO general purpose metric screw threads - Part 1: Nominal sizes for coarse pitch threads; nominal diameter from 1 mm to 68 mm
Din 13-19:
ISO general purpose metric screw threads - Part 19: Nominal profiles
DIN 13-20:
ISO general purpose metric screw threads - Part 20: Limits of sizes for coarse pitch threads with the prefered tolerance classes; nominal sizes from 1 mm to 68 mm
JelteDeJong
depending on your use case you could do a google picture search for Din 61. That way i found a couple of drawings with dimensions that could be good enoug for you.
Jelte de Jong
Blog: hjalte.nl - github.com
