Create drawing list from top level assembly
Message 1 of 22
I would like to create a drawing list from a top level assembly in Excel.
The drawing list must contain the following:
- Part number
- Description
- Total quantity of the parts / sub assemblies / assemblies
I hope someone can help me to solve this problem. It would save me a lot of time because I have to make the drawing list now by hand. I need to count all by hand an it is just waiting for mistakes.
Thanks a lot.
Jeffrey
Replies (21)
Message 2 of 22
NachoShaw
Hi
You can look at the BOM for this from the Assembly. go to:
Manage / Bill of Materials
select the columns you want to see
pick 'Parts only' in the dropdrown list
export to excel
Cheers
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 3 of 22
That is not what I want.. but thanks for your help!
I just need a list with all existing part numbers within a top assembly (only from the parts / assemblies where the bom structure is normal!).
In that list I want to see the total quantity of parts / sub assemblies etc.
Inventor is not giving this information in the parts only or structured bom view.
I hope that my question is a clearer now.
Jeffrey
Message 4 of 22
NachoShaw
Then im not sure what you want?
If you want a list from the top level assembly, you can get it from the BOM. If you only want to focus on the parts / assemblies that have a normal structure, filter them out in excel and delete them. All of the columns that want are there
Nacho
Message 5 of 22
Please find some examples below.
Example of what a structured bom inventor can look like:
Part number                   Description         QTY        BOM Structure
10000                         Assembly            2          Normal
     10001                    Sub ass.            1          Normal
           10003              Part 1              8          Normal
           10004              Part 2              2          Normal
10016 Festo cylinder 3 Purchased
Example of what I want to achieve:
10000                        Assembly                  2
10001                        Sub ass.                  2
10003                        Part 1                    16
10004                        Part 2                    4
This is not the same as the structured or parts only bom in Inventor.
Jeffrey
Message 6 of 22
bradeneuropeArthur
Use structured all levels in the BOM.
Other possible solution:
Are you using Vault?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 7 of 22
NachoShaw
This IS achievable using the BOM from a top level assembly on a drawing sheet with a Part List.
This is how i did it:
  • Added base view of top level assembly
  • created a partslist style with Part Number, Description & Base Qty as the Columns
  • clicked 'Filter' above the column display box
  • selected 'Purchased Items' in the dropdown box
  • Selected 'No Purchased Items' from the radio selection
  • saved and closed the styles editor
  • added partlist with settings BOM View = Structured (Legacy)
  • Selected the baseview and placed the partlist.
  • changed the partlist style to the one i have just created
  • double clicked the partlist to edit
  • expanded all of the collapsed rows
  • clicked ok
  • clicked ok
  • right click the partlist and select Export
That will give you exactly what you have shown above from the BOM
Nacho
Message 8 of 22
Sorry for the late response.
This still does not make the list that I am looking for.
I Solved this now by making an excel sheet with some VBA in it.
Topic may be closed.
Jeffrey
Message 9 of 22
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 22
Yes I use Vault professional.
Jeffrey
Message 11 of 22
bradeneuropeArthur
Why not using vault for this!?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 22
I realy don't know how to achieve this in Vault..
We don't have a ERP system yet..
Jeffrey
Message 13 of 22
bradeneuropeArthur
there is a feature in vault that does this too..
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 22
Can you perhaps explain how this works?
Jeffrey
Message 15 of 22
bradeneuropeArthur
I will try...
keep following this...
Keep reading...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 22
bradeneuropeArthur
Select any folder in vault.
  • Goto>> File >> Plot.
  • Select >> Add >> Add Related File sheets
  • Select >> The Top Level Drawing in the browser
  • Vault start Calculating processing the related drawings...
  • The list is shown now.
  • Goto >> File (in the active browser)
  • Select export
  • now you have your list...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 22
I'm going to try it tomorrow.
Thank you for your solution.
Jeffrey
Message 18 of 22
Message 19 of 22
bradeneuropeArthur
Yes this is also possible without vault, but you need to have all files available on your machine.
The issue is much more easier with the vault.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 22
Can you tell how to do this without Vault?
