Ilogic rule to retrieve parameters and bypass if not exist.
Message 1 of 11
I wrote a rule to retrieve values from parameters, but if the parameters doesn't not exist from the model. The program complain and won't run. How can I bypass if the parameters does't not exist.
Following is the code:
SyntaxEditor Code Snippet
'Extract Information from the part to a text file
 'My.Computer.FileSystem.WriteAllText("C:\TestFolder1\test.txt", Title + vbNewLine + Mfg + vbNewLine+ Mfg_no+ vbNewLine + SuggestedVendor +vbNewLine + SuggestedVendorPartNumber + vbNewLine + DST_Cost ,True
 'part_Number = iProperties.Value("Project", "Part Number")
 Dim part_Number As String
 Dim part_Revision As String
 Dim sFileName As String
 Dim tabs As String = "ITEM    QTY    PART_NO    DESCRIPTION    REFERENCE"
 Dim sp As String = "            "
 Dim fFile As IO.File
 Dim pTitle As String
 Dim pMfg As String
 Dim pMfg_no As String
 Dim pSuggestedVendor As String
 Dim pSuggestedVendorPartNumber As String
 Dim pDST_Cost As String
 part_Number = ThisDoc.FileName
 part_Revision = iProperties.Value("Project", "Revision Number")
 If iProperties.Value("Custom", "Title") = Isempty Then
     pTitle = Isempty
 Else
    pTitle = iProperties.Value("Custom", "Title")
 If (iProperties.Value("Custom", "Mfg")) = Isempty Then
     pMfg = Isempty
 Else
     pMfg = iProperties.Value("Custom", "Mfg")
 If (iProperties.Value("Custom", "Mfg_no")) = Isempty Then
      pMfg_no = Isempty
 Else
     pMfg_no = iProperties.Value("Custom", "Mfg_no")
If (iProperties.Value("Custom", "SuggestedVendor")) = Isempty Then
     pSuggestedVendor = Isempty
Else
    pSuggestedVendor = iProperties.Value("Custom", "SuggestedVendor")
If (iProperties.Value("Custom", "SuggestedVendorPartNumber")) = Isempty Then
     pSuggestedVendorPartNumber = Isempty
Else
    pSuggestedVendorPartNumber = iProperties.Value("Custom", "SuggestedVendorPartNumber")
If (iProperties.Value("Custom", "DST_Cost")) = Isempty Then
     pDST_Cost = Isempty
Else
    pDST_Cost = iProperties.Value("Custom", "DST_Cost")
  My.Computer.FileSystem.WriteAllText("C:\TestFolder1\"+part_Number+"_R0"+part_Revision+".txt", tabs +vbNewLine +"1"+sp+ pTitle + vbNewLine +"2"+sp+ pMfg + vbNewLine +"3"+sp+pMfg_no+vbNewLine+"4"+sp+ iProperties.Value("Custom", "SuggestedVendor") +vbNewLine +"5"+sp+iProperties.Value("Custom", "SuggestedVendorPartNumber") + vbNewLine +"6"+sp+ iProperties.Value("Custom", "DST_Cost") ,True, System.Text.Encoding.ASCII)
 iLogicVb.UpdateWhenDone = True
Replies (10)
Message 2 of 11
Xun.Zhang
@YuhanZhang, Any best practice to ignore empty property?
Thanks!
Xun
Message 3 of 11
bradeneuropeArthur
resume next Else
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 11
bradeneuropeArthur
Do this:
try
Else
catch
end try
This is how you first check if the property exist in the file.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 11
I changed the code per your suggestion but I am getting different errors.
Try
    If(iProperties.Value("Custom", "SuggestedVendor")) = Isempty Then
    Else
Catch
End Try
the ERROR is
Error on line 50: Property access must assign to the property or use its value.
Line 50:
Message 6 of 11
YuhanZhang
Here is a sample iLogic code to check if a custom property is already defined:
On Error Resume Next
If Err.Number <> 0 Then
	Err.Clear
On Error GoTo 0
Hope it helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 7 of 11
Yuhan Zhang,
That code work perfectly ,  it does everything  I need to extract custom iProperties from my part.ipt. But when I tried to extract custom iProperties from my drawing.idw, there are some issues:
1) My model custom iProperties are not transfer to my drawing.idw, therefore some of custom iProperties are blank.
2) I manually link my drawing with my model:
Tools -> Document Setting -> Drawing Tabs -> Copy Model iProperty Settings -> select All Properties
Is there any iLogic rules or macro that I can write to do the task to be able to update iProperties from model to drawing.
Message 8 of 11
YuhanZhang
You can copy the model custom properties to the drawing document using iLogic, below is a sample iLogic code, you can run it in a drawing document:
Sub Main()
	' get the first model document referenced by the drawing document.
	Dim oModelDoc As Document
	oModelDoc = ThisDrawing.ModelDocument 'oBase.ReferencedDocumentDescriptor.ReferencedDocument
	Dim oDrawDoc As DrawingDocument
	oDrawDoc = ThisDrawing.Document
	' copy all the custom properties from the model document to drawing document.
	Dim oCustomProp As Inventor.Property
	Dim oProp As Inventor.Property
	For Each oCustomProp In oModelDoc.PropertySets(4)
		' check if the drawing document already has a custom property from model document
		oProp = oDrawDoc.PropertySets(4).Item(oCustomProp.Name)
			Err.Clear
			oProp = oDrawDoc.PropertySets(4).Add(oCustomProp.Value, oCustomProp.Name)
		Else
			oProp.Value = oCustomProp.Value
		oProp = Nothing
	Next
	On Error GoTo 0
End Sub
Please let me if more questions.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 9 of 11
RoyWickrama_RWEI
Nice coding. I like it.
With an iLogic rule running in a drawing document, I am interested retrieving the custom properties of a document (part or assembly) which is different from the drawing-model-document. Path and file name of this non-drawing-model-document is known.
I tried with my ability, but no success yet. I appreciate if you could you help me or provide with some hint to get this around.
Message 10 of 11
YuhanZhang
Try below iLogic code, change the sPath to your model's full filename:
Sub Main()
	' get the model document.
	Dim sPath As String
	sPath = "C:\Temp\MyModel.ipt"
oModelDoc = ThisApplication.Documents.Open(sPath, False)
			Err.Clear
		Else
		oProp = Nothing
	Next
	On Error GoTo 0
End Sub
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 11 of 11
RoyWickrama_RWEI
Hi YuhanZhang;
It is a great help. It works fine 100%. Also, it helped me to around my current need (that I tested with the sample code shown below):
Sub Main()
	Dim sPath As String
	sPath = "C:\$WF_DHAMAG\Projects\DHAMAG_SDAI\ADSI-P001-ARF33\P001-A0001.iam"
oCustomProp_X = "TOTAL QTY"
	oPropsSet = oModelDoc.PropertySets.Item("Inventor User Defined Properties")
	For Each oCustomProp In oPropsSet		'oModelDoc.PropertySets(4)
			If oCustomProp.Name = oCustomProp_X Then
			MessageBox.Show("oCustomProp.Name: " & oCustomProp.Name _
			& vbLf & "oCustomProp.Value: " & oCustomProp.Value, "Title")
	Next oCustomProp
	oTest = iProperties.Value(oModelDoc, "Custom", oCustomProp_X)
	MessageBox.Show("@ Err!", "Title")
		Err.Clear
		oProp = oPropsSet.Add("", oCustomProp_X)
		MessageBox.Show("Created!", "Title")
End Sub
Thanks a lot.
The idea of the oModelDoc using sPath is great.
