Create drawing list from top level assembly
Message 1 of 22
I would like to create a drawing list from a top level assembly in Excel.
The drawing list must contain the following:
- Part number
- Description
- Total quantity of the parts / sub assemblies / assemblies
I hope someone can help me to solve this problem. It would save me a lot of time because I have to make the drawing list now by hand. I need to count all by hand an it is just waiting for mistakes.
Thanks a lot.
Jeffrey
Replies (21)
Message 21 of 22
bradeneuropeArthur
I need some time for this, but i will ask again.
Are you sure that you are having all related files locally on your machine?
Otherwise inventor is not able to find the related drawing files.
If you are always sure of having all files locally, then this idea may work.
Otherwise not! please take that into consideration.
As already told the method in vault is the easiest and the most secure way of doing this.
The method you should use is:
Loop through the BOM
and take a look with "WhereUsed" in inventor. If this is a dwg file than list it...
Please let me know you preferences.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 22 of 22
OK. my files are on a shared network drive... thanks anyway.
