Conversion from inventor part file to step or igs file in c#
Message 1 of 9
Hello All experts
Please any one support for below mentioned points
1)  Conversion from inventor part file to step or igs file in c# code.
2)  Conversion from inventor drawing file to auto cad drawing file in c# code.
Thank you
Reagrds
Naveen
Replies (8)
Message 2 of 9
bradeneuropeArthur
This should help you.
I have copied it from the programming help from inventor:
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
Thank you sir ........thanks for reply
Is there any method  to convert
1) inventor part file to uni graphics part file(.ipt to .prt).
2) inventor drawing  file to uni graphics drawing file.
Thank you
Reagrds
Naveen
Message 4 of 9
bradeneuropeArthur
I think not directly!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 9
i think
inventor to step / iges and then convert step to unigaraphics.
Above all steps in a single macro is it possible? please help me.
Please support on this
Thank you in adavance
Message 6 of 9
bradeneuropeArthur
What application should export step file to unigraphics?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 9
It's conversion requirement
Inventor part file to unigraphics
Inventor dwg file to unigraphicd
Message 8 of 9
bradeneuropeArthur
You wrote step to iges and than to unigraphics.
Who should do the second step. Inventor is not able to do that I think.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 9
Maybe CrossManager can help you: It can convert Inventor files to STEP, IGES, NX, and many other CAD formats.
There is an advanced version allowing to call it with a script.
