Control Inventor Application Option using Macro
Hi Team,
Is there a  way to control the Inventor Application Option settings using macro?
I would like to change the folder location to new one
Application.FileOptions.DesignDataPath
Is it possible? Or through Project settings?
Regards
Alex
bradeneuropeArthur
Dim ap As Application
Set ap = ThisApplication
ap.FileOptions.DefaultVBAProjectFileFullFilename = "c:\..........."
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Hi All,
Yes. Was making silly mistake.
I could able to change the Settings of below to a new path;
Msgbox CAD Templates Path  : " & ThisApplication.FileOptions.TemplatesPath
Msgbox Design Data Path    : " & ThisApplication.FileOptions.DesignDataPath
Msgbox Symbol Library Path : " & ThisApplication.FileOptions.SymbolLibraryPath
RegarRegRERegards,REga
Regards
Alex
Hi
Yes. Was making silly mistake. Now I could able to change the Settings of below to a new path;
Regards
Alex
bradeneuropeArthur
solved then for you.
Or do you need further support?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
I think I am ok now.
Thank you..
Will post if I get any new problems 🙂
Regards
Alex
bradeneuropeArthur
Then mark  this post as solved solution please
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
