Set check date using iLogic Rule
I want to set the checked date to the current date by using a ilogic rule. Can anyone help
bradeneuropeArthur
Checked date in inventor iproperty or what?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
SyntaxEditor Code Snippet
If (ThisDoc.Document.DocumentType <> kDrawingDocumentObject) Then Return
Dim odrawdoc As DrawingDocument
odrawdoc = ThisDoc.Document
If (odrawdoc Is Nothing) Then Return
customPropertySet=odrawdoc.PropertySets.Item("Inventor User Defined Properties")
iProperties.Value("Project", "Checked Date")=Now
InventorVb.DocumentUpdate()
tkennedy26
This should do it.
iProperties.Value("Project", "Checked Date") = Now
bradeneuropeArthur
What is going wrong then.
You may be need to format your date now to the requirements.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Sorry, i have solved this now, with the code i posted.
bradeneuropeArthur
You can solve it yourselves also!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
