Code not working in 2018 but works in 2012
jletcher
Advisor Advisor
Message 1 of 169
jletcher
 I have looked this over and I can't figure out why it is giving me this error.
1st time I even seen this kind of error on ilogic.
I supplied the part I will warn you don't hit continue it will stick you in a loop and you will have to force close Inventor.
Now this is in a library folder it works if the part is in the project workspace but I can't have that they need to be in a library so they cannot modify the part by accident .
It works fine in 2012 as a library but not in 2018.
Thanks for the help.
Replies (168)
Message 2 of 169
bradeneuropeArthur
Can you please upload the code as text!?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 169
Mike.Wohletz
I have opened the part and made a couple of edits using 2018 and have no issues or errors.
Message 4 of 169
jletcher
Dim fileName As String
Dim path As String
path = ThisDoc.WorkspacePath()
fileName = "filename"
ThisDoc.Document.SaveAs(path & "\" & "900C7H" & L_1 & ".ipt" , False)
doc = ThisDoc.Document
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
iLogicVb.UpdateWhenDone = True
MessageBox.Show("Your file has been made", "SPACER")
Message 5 of 169
jletcher
Did you put it in a library and mapped in projects?
It works if it is in the project folder but not in library..
Message 6 of 169
pball
Since you said this is in a library folder, it could be related to the "bug fix" in 2018 which removes the ability for the API to modify library parts. In the past the API could edit parts in library folders that could not be edited manually. That issue is discussed along with a hidden bypass for the fix added in 2018.2 in the thread below.
https://forums.autodesk.com/t5/inventor-customization/ilogic-error/td-p/7133836
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Message 7 of 169
jletcher
Knock knock anyone here?
 Come on Autodesk I need answers.......
Client needs to make parts..............
Message 8 of 169
jletcher
 OH so the service pack that fails to install is the thing I need to fix this...
HOW NICE Smiley Mad
Message 9 of 169
bradeneuropeArthur
What went wrong?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 169
jletcher
Loaded both updates and it does not fix my issue..
Message 11 of 169
jletcher
 If you are talking about the update I guess I had to load 2018.2 before I load 2018.2.1
 But neither of the updates fixed my issue..
Message 12 of 169
ChrisMitchell01
In VBA, you now have to use:
ThisApplication.[_LibraryDocumentModifiable] = True
That also works in iLogic.
-Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 13 of 169
MechMachineMan
Put this line in it's own rule, run it, then try your code again:
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 14 of 169
jletcher
No luck...
 Put it in his own did not work and would not let me exit so I had to task manager close Inventor..
Message 15 of 169
bradeneuropeArthur
Did you try
makedirectory for each directory
like:
on error resume next
Mkdir "C\Test"
Mdir "C\Test\Directory1"
Mdir "C\Test\Directory1\Directory2"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 169
bradeneuropeArthur
last option could be:
this allows you to edit the Content Center part;
ThisApplication._LibraryDocumentModifiable = True
Don't forget to set it back to false for the Application
with:
ThisApplication._LibraryDocumentModifiable = false
Completed Code:
Dim path As String
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 169
jletcher
Not sure what you mean by make directory for each directory..
 I need it to go into the project path..
Message 18 of 169
bradeneuropeArthur
you need to create the directory step by step (Per directory) when not existing yet.
for example:
you nee directory which is not existing:
like:
then you need to do it like
Mkdir "C\Test"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 169
jletcher
OK that code works but needs to be the 1st rule in the list
Message 20 of 169
bradeneuropeArthur
Don't forget to set the value to False again!!!
To prevent you from problems as written in my post.
Good to here that it has been solved.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
