Apprentice, can't access drawing symbols & part lists
ChristiPedersen
ChristiPedersen
We are moving away from generating BOM's inside Inventor and using Apprentice through the assembly.  There are a few things I need from the drawing file though.  I have reviewed the document below from 2011 which only lists a few things I can obtain from the drawing in Apprentice.  I would like to access the sketched symbols and custom build tables.  Before I assume not, I just want to make sure these are not available through Apprentice currently.  Both say not supported when I try to get to them.
document http://aucache.autodesk.com/au2011/sessions/5606/class_presentations/v1_CP5606-Apprentice.pdf
BrianEkins
They are not available through Apprentice and I wouldn't expect this to change.  If they are all you're missing, one workaround would be to write an add-in that would run in the drawing when you save it and extract whatever information you need from the drawing symbols and parts lists and save it as either an iProperty or attribute, both of which are accessible through Apprentice.
Brian Ekins
bradeneuropeArthur
Are you using Vault Pro or Workgroup?
Then there are other possibilities to extract this data.
You could use Inventor Server for this.
Please let me know if you need more info regarding this?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Mario-Villada
Hi mate, Can send me info in Inventor serer please?
bradeneuropeArthur
Hi @Mario-Villada ,
Are familiar with programming Vault jobserver Extensions!?
Otherwise it will be a hard job, if you are not!.
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Mario-Villada
I am familiar with automating other packages through  its com object. If I have the libraries, the exposed objects and methods I am confident I can  do it.
