Adding Entries in combobox
Message 1 of 10
I Want to add X and Y in combo box
and when i select the drop down for this combo box x and y should reflect in the list for selection
Replies (9)
Message 2 of 10
MechMachineMan
Ok. Is there 1 list that just contains X and Y that you want?
If so, use the iLogic Snippet "InputListBox". Plenty of examples around on how to use it.
Do you want the form to have 2 lists?
If so, you either need to make a custom form in visual studio, or use 2 InputListBoxes to accomplish the same thing.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 10
I just want simple one list containing only 2 entries
Message 4 of 10
bradeneuropeArthur
in I-logic; VBA or in VB.net?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 10
MechMachineMan
Use a radio box then.
They're documented fairly well in the Autodesk Help files...
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-1A217E8E-FE3A-4E84-9926-8E11C81D60D9
Justin K
Message 6 of 10
in VBA
Message 7 of 10
bradeneuropeArthur
Private Sub UserForm_Activate()
Me.ListBox1.AddItem "x", 0
Me.ListBox1.AddItem "y", 0
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
jR0sal3s
hello...would you show an example on how to link combo box/list box to excel in vba?
Message 9 of 10
bradeneuropeArthur
What do you exactly mean?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
jR0sal3s
what i meant is, if you have a combo or list box that is populated by data from excel file...or the list that would appear in the list box or combo box is linked to an excel file...how would you do that?
