Inventor Layers and line types
tschaeferZNBXX
Advisor Advisor
Message 1 of 9
tschaeferZNBXX
Before I get racked over the coals, yes I know this is a little backwards thinking!
My question is does anyone know a way to get still show line types if I am using layers in Inventor?  I am looking for a way to still show a view in a certain color but also have the visible and hidden line types.
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Replies (8)
Message 2 of 9
mcgyvr
Your 2nd sentence got a little confusing but based on the 3rd one is this what you are asking for?
A way to just change the color of all linework (be it solid or hidden or whatever) for a particular view...
base view and 2 projected views shown here..
Message 3 of 9
tschaeferZNBXX
Yes that is correct.  I am using this code below to update all the views on multiple sheets but the different line types come in as solid lines.
SyntaxEditor Code Snippet
Sub Main
    ' Get the active drawing document.
    Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oSheets As Sheets
    oSheets = oDoc.Sheets
    Dim oSheet As Sheet
    'get current sheet so it can
    'be made active again later
    Dim oCurrentSheet As Sheet
    oCurrentSheet = oDoc.ActiveSheet
    Dim oViews As DrawingViews
    Dim oView As DrawingView
    ' Iterate through the sheets
    For Each oSheet In oSheets
    '    activate the sheet
        oSheet.Activate
        'get the collection of view on the sheet
        oViews = oSheet.DrawingViews
        ' Iterate through the views on the sheet
        For Each oView In oViews
            Dim docDesc As DocumentDescriptor
            docDesc = oView.ReferencedDocumentDescriptor
            ' Verify that the drawing view is of an assembly.
            If docDesc.ReferencedDocumentType <> kAssemblyDocumentObject Then
                Continue For
            ' Get the component definition for the assembly.
            Dim asmDef As AssemblyComponentDefinition
            asmDef = docDesc.ReferencedDocument.ComponentDefinition
            ' Process the view, wrapping it in a transaction so the
            ' each view can be undone with a single undo operation.
            Dim trans As Transaction
            trans = ThisApplication.TransactionManager.StartTransaction( _
                                    oDoc, "Change drawing view color")
            ' Call the recursive function that does all the work.
            Call ProcessAssemblyColor(oView, asmDef.Occurrences)
            trans.End
        Next
        'update the sheet
        oSheet.Update
    Next
    'return to original sheet
    oCurrentSheet.Activate
End Sub
Private Sub ProcessAssemblyColor(drawView As DrawingView, _
                                 Occurrences As ComponentOccurrences)
   ' Iterate through the current collection of occurrences.
   Dim occ As ComponentOccurrence
   For Each occ In Occurrences
      ' Check to see if this occurrence is a part or assembly.
      If occ.DefinitionDocumentType = kPartDocumentObject Then
         ' ** It's a part so process the color.
         ' Get the render style of the occurrence.
         Dim color As RenderStyle
         Dim sourceType As StyleSourceTypeEnum
         color = occ.GetRenderStyle(sourceType)
         ' Get the TransientsObjects object to use later.
         Dim transObjs As TransientObjects
         transObjs = ThisApplication.TransientObjects
         ' Verify that a layer exists for this color.
         Dim layers As LayersEnumerator
         layers = drawView.Parent.Parent.StylesManager.layers
         oDoc = drawView.Parent.Parent
         On Error Resume Next
         Dim colorLayer As Layer
         colorLayer = layers.Item(color.Name)
         If Err.Number <> 0 Then
            On Error Goto 0
            ' Get the diffuse color for the render style.
            Dim red As Byte
            Dim green As Byte
            Dim blue As Byte
            ' Create a color object that is the diffuse color.
            Call color.GetDiffuseColor(red, green, blue)
            Dim newColor As color
            newColor = transObjs.CreateColor(red, green, blue)
            ' Copy an arbitrary layer giving it the name
            ' of the render style.
            colorLayer = layers.Item(1).Copy(color.Name)
            ' the attributes of the layer to use the color,
            ' have a solid line type, and a specific width.
            colorLayer.Color = newColor
            colorLayer.LineType = kContinuousLineType
            colorLayer.LineWeight = 0.02
         On Error Goto 0
         ' Get all of the curves associated with this occurrence.
         Dim drawcurves As DrawingCurvesEnumerator
         drawcurves = drawView.DrawingCurves(occ)
         If Err.Number = 0 Then
            On Error Goto 0
            ' Create an empty collection.
            Dim objColl As ObjectCollection
            objColl = transObjs.CreateObjectCollection()
            ' Add the curve segments to the collection.
            Dim drawCurve As DrawingCurve
            For Each drawCurve In drawcurves
               Dim segment As DrawingCurveSegment
               For Each segment In drawCurve.Segments
                  objColl.Add (segment)
               Next
            Next
            ' Change the layer of all of the segments.
            Call drawView.Parent.ChangeLayer(objColl, colorLayer)
         On Error Goto 0
      Else
         ' It's an assembly so process its contents.
         Call ProcessAssemblyColor(drawView, occ.SubOccurrences)
   Next
End Sub
*AU Speaker 2018*
* AU Speaker 2017 *
Message 4 of 9
mcgyvr
oh and now a mention of code...better late than never I guess
Smiley Tongue
Busy now..
Message 5 of 9
tschaeferZNBXX
Hey just want to keep you guys and gals busy.
*AU Speaker 2018*
* AU Speaker 2017 *
Message 6 of 9
As if we don't have enough on our plates already...;)
Message 7 of 9
tschaeferZNBXX
@mcgyvr have you had a chance to look at this or can you guide me to the answer?
I am assuming that the answer is adding a line in the iLogic to change the hidden line type to the same layer as the model just not sure how to do this.
*AU Speaker 2018*
* AU Speaker 2017 *
Message 8 of 9
mcgyvr
@tschaeferZNBXX This one is out of my league due to the ilogic coding....  I'm sure it must be possible as I can manually/easily change the color of the line work but I don't know that ilogic stuff well enough in this situation to be of any help..  Sorry..
Is there a reason you are changing the layer and not just changing the color of the curves?
Message 9 of 9
tschaeferZNBXX
@mcgyvr no worries, thank you for trying.
Our customers require AutoCAD files with Layers as a deliverable when we finish a project.  We currently spend a lot of time doing this at the end of a project to get this completed from Inventor.  We are trying to get this changed but it can be difficult to get things changed quickly so the idea was to use this as a gap closer.
*AU Speaker 2018*
* AU Speaker 2017 *
