Message 1 of 17
acad.exe link problem!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i have a old rule who working great until a install inventor 2026???
i just change the new link but error message!
any body can help me???
sorry for my horrible english!
my old rule:
' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "I:\INVENTOR\ILOGIC\TEMPLATE\DXFOut.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If DOSSIER = ThisDoc.Path POSITION1 = InStrRev(DOSSIER, "\") POSITION2 = Right(DOSSIER, Len(DOSSIER) - POSITION1) 'get DXF target folder path oFolder = "I:\DOCUMENTS\ARTICLES\" & POSITION2 & "\" oFileName = ThisDoc.FileName(False) 'without extension 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If For i = 1 To 100 chiffre = i myFile = oFolder & oFileName & "_Sheet_" & chiffre & ".dxf" If(System.IO.File.Exists(myFile)) Then Kill (myFile) End If Next i 'Set the destination file name oDataMedium.FileName = oFolder & oFileName & ".dxf" oFileName = ThisDoc.FileName(False) 'without extension 'Publish document. DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with myFile2 = oFolder & oFileName & "_Sheet_" & 100 & ".dxf" If(System.IO.File.Exists(myFile2)) Then Kill (myFile2) End If ' Get the DWG translator Add-In. Dim oDWGAddIn As TranslatorAddIn oDWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") ' Check whether the translator has 'SaveCopyAs' options If oDWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "I:\INVENTOR\ILOGIC\TEMPLATE\DWGOut.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'get DXF target folder path oFolder2 = "I:\DOCUMENTS\ARTICLES\" & POSITION2 & "\" oFileName2 = ThisDoc.FileName(False) 'without extension 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder2) Then System.IO.Directory.CreateDirectory(oFolder2) End If For i = 1 To 100 chiffre2 = i myFile2 = oFolder2 & oFileName2 & "_Sheet_" & chiffre2 & ".dwg" If(System.IO.File.Exists(myFile2)) Then Kill (myFile2) End If Next i 'Set the destination file name oDataMedium.FileName = oFolder2 & oFileName2 & ".dwg" oFileName2 = ThisDoc.FileName(False) 'without extension 'Publish document. oDWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with myFile2 = oFolder2 & oFileName2 & "_Sheet_" & 100 & ".dwg" If(System.IO.File.Exists(myFile2)) Then Kill (myFile2) End If question = MessageBox.Show("VEUX-TU OUVRIR AUTOCAD POUR PURGER TES DESSINS???", "OUVERTURE AUTOCAD???", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) MultiValue.SetValueOptions(True) If question = vbYes Then GoTo OUVERTURE Else If question = vbNo Then GoTo FIN End If OUVERTURE : Dim acadExe = "C:\Program Files\Autodesk\AutoCAD 2025\acad.exe" 'MessageBox.Show("N'OUBLIE PAS DE SAUVER EN VERSION 2000, UNE FOIS TON DESSIN PURGER ET DE PURGER TOUTES TES PAGES", "ATTENTION",MessageBoxButtons.OK,MessageBoxIcon.Warning) Process.Start(acadExe, oFolder2 & oFileName2 & "_Sheet_" & 1 & ".dwg") FIN:
my new rule with new link of acad:
' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "I:\INVENTOR\ILOGIC\TEMPLATE\DXFOut.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If DOSSIER = ThisDoc.Path POSITION1 = InStrRev(DOSSIER, "\") POSITION2 = Right(DOSSIER, Len(DOSSIER) - POSITION1) 'get DXF target folder path oFolder = "I:\DOCUMENTS\ARTICLES\" & POSITION2 & "\" oFileName = ThisDoc.FileName(False) 'without extension 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If For i = 1 To 100 chiffre = i myFile = oFolder & oFileName & "_Sheet_" & chiffre & ".dxf" If(System.IO.File.Exists(myFile)) Then Kill (myFile) End If Next i 'Set the destination file name oDataMedium.FileName = oFolder & oFileName & ".dxf" oFileName = ThisDoc.FileName(False) 'without extension 'Publish document. DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with myFile2 = oFolder & oFileName & "_Sheet_" & 100 & ".dxf" If(System.IO.File.Exists(myFile2)) Then Kill (myFile2) End If ' Get the DWG translator Add-In. Dim oDWGAddIn As TranslatorAddIn oDWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") ' Check whether the translator has 'SaveCopyAs' options If oDWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "I:\INVENTOR\ILOGIC\TEMPLATE\DWGOut.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'get DXF target folder path oFolder2 = "I:\DOCUMENTS\ARTICLES\" & POSITION2 & "\" oFileName2 = ThisDoc.FileName(False) 'without extension 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder2) Then System.IO.Directory.CreateDirectory(oFolder2) End If For i = 1 To 100 chiffre2 = i myFile2 = oFolder2 & oFileName2 & "_Sheet_" & chiffre2 & ".dwg" If(System.IO.File.Exists(myFile2)) Then Kill (myFile2) End If Next i 'Set the destination file name oDataMedium.FileName = oFolder2 & oFileName2 & ".dwg" oFileName2 = ThisDoc.FileName(False) 'without extension 'Publish document. oDWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with myFile2 = oFolder2 & oFileName2 & "_Sheet_" & 100 & ".dwg" If(System.IO.File.Exists(myFile2)) Then Kill (myFile2) End If question = MessageBox.Show("VEUX-TU OUVRIR AUTOCAD POUR PURGER TES DESSINS???", "OUVERTURE AUTOCAD???", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) MultiValue.SetValueOptions(True) If question = vbYes Then GoTo OUVERTURE Else If question = vbNo Then GoTo FIN End If OUVERTURE : Dim acadExe = "C:\Program Files\Autodesk\AutoCAD 2026\acad.exe" 'MessageBox.Show("N'OUBLIE PAS DE SAUVER EN VERSION 2000, UNE FOIS TON DESSIN PURGER ET DE PURGER TOUTES TES PAGES", "ATTENTION",MessageBoxButtons.OK,MessageBoxIcon.Warning) Process.Start(acadExe, oFolder2 & oFileName2 & "_Sheet_" & 1 & ".dwg") FIN:
