Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
acad.exe link problem!
SergeLachance
Message 1 of 19
SergeLachance
i have a old rule who working great until a install inventor 2026???
i just change the new link but error message!
any body can help me???
sorry for my horrible english!
my old rule:
' Get the DXF translator Add-In.
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "I:\INVENTOR\ILOGIC\TEMPLATE\DXFOut.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
DOSSIER = ThisDoc.Path
POSITION1 = InStrRev(DOSSIER, "\")
POSITION2 = Right(DOSSIER, Len(DOSSIER) - POSITION1)
'get DXF target folder path
oFolder = "I:\DOCUMENTS\ARTICLES\" & POSITION2 & "\"
oFileName = ThisDoc.FileName(False) 'without extension
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
For i = 1 To 100
chiffre = i
myFile = oFolder & oFileName & "_Sheet_" & chiffre & ".dxf"
If(System.IO.File.Exists(myFile)) Then
Kill (myFile)
End If
Next i
'Set the destination file name
oDataMedium.FileName = oFolder & oFileName & ".dxf"
'Publish document.
DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Launch the dxf file in whatever application Windows is set to open this document type with
myFile2 = oFolder & oFileName & "_Sheet_" & 100 & ".dxf"
If(System.IO.File.Exists(myFile2)) Then
Kill (myFile2)
End If
' Get the DWG translator Add-In.
Dim oDWGAddIn As TranslatorAddIn
oDWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
If oDWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
strIniFile = "I:\INVENTOR\ILOGIC\TEMPLATE\DWGOut.ini"
End If
oFolder2 = "I:\DOCUMENTS\ARTICLES\" & POSITION2 & "\"
oFileName2 = ThisDoc.FileName(False) 'without extension
If Not System.IO.Directory.Exists(oFolder2) Then
    System.IO.Directory.CreateDirectory(oFolder2)
End If
For i = 1 To 100
chiffre2 = i
myFile2 = oFolder2 & oFileName2 & "_Sheet_" & chiffre2 & ".dwg"
Kill (myFile2)
End If
Next i
oDataMedium.FileName = oFolder2 & oFileName2 & ".dwg"
'Publish document.
oDWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
myFile2 = oFolder2 & oFileName2 & "_Sheet_" & 100 & ".dwg"
Kill (myFile2)
End If
question = MessageBox.Show("VEUX-TU OUVRIR AUTOCAD POUR PURGER TES DESSINS???", "OUVERTURE AUTOCAD???", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
MultiValue.SetValueOptions(True)
If question = vbYes Then
GoTo OUVERTURE
Else If question = vbNo Then
GoTo FIN
End If
OUVERTURE :
Dim acadExe = "C:\Program Files\Autodesk\AutoCAD 2025\acad.exe"
'MessageBox.Show("N'OUBLIE PAS DE SAUVER EN VERSION 2000, UNE FOIS TON DESSIN PURGER ET DE PURGER TOUTES TES PAGES", "ATTENTION",MessageBoxButtons.OK,MessageBoxIcon.Warning)
Process.Start(acadExe, oFolder2 & oFileName2 & "_Sheet_" & 1 & ".dwg")
FIN:
my new rule with new link of acad:
End If
End If
For i = 1 To 100
chiffre = i
Kill (myFile)
End If
Next i
'Publish document.
Kill (myFile2)
End If
End If
End If
For i = 1 To 100
chiffre2 = i
Kill (myFile2)
End If
Next i
'Publish document.
Kill (myFile2)
End If
GoTo OUVERTURE
GoTo FIN
End If
OUVERTURE :
Dim acadExe = "‪‪C:\Program Files\Autodesk\AutoCAD 2026\acad.exe"
FIN:
Replies (18)
Message 2 of 19
bradeneuropeArthur
can you try this out:
I think if this works that it is not the acad.exe related but the drive "I" related.
It is better to use the server name instead of the drive letter name!
Process.Start(acadExe)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 19
SergeLachance
Thank for your reply 🙂
I have only change the acad.exe link
for what you talking about ''I'' ?
Message 4 of 19
bradeneuropeArthur
The code goes wrong on line 111
This is where you open acad with parameters to the I drive
To eliminate that this is the case use my test code to have a look if the acad exe is the problem or the I drive.
Using the drive letter in code is not best practice. Using the server name is in this case better.
For example what if the server is not available?
This possibly is best to check.
So please test this first:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 19
SergeLachance
THANKS AGAIN FOR YOUR TIMES 🙂
i try it but dont work again 😞
Message 6 of 19
bradeneuropeArthur
can you test with a new rule the following:
Process.Start(acad.exe)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 19
bradeneuropeArthur
could this be the solution maybe:
https://forums.autodesk.com/t5/inventor-programming-forum/fail-to-use-process-start-in-inventor-2025...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 19
SergeLachance
i have allready test it!
i have remove my link to just try to open autocad, and i have reinstall autocad 2026 2 times!
without succes 😞
Message 9 of 19
bradeneuropeArthur
maybe this is relevant for you too then:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/FATAL-ERROR-ASC-in...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 19
SergeLachance
i have allready reinstall autocad 2026 and i dont use vault!
Message 11 of 19
bradeneuropeArthur
can you start via explorer:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 19
SergeLachance
yes when i click on the icon acad.exe on my C:
is starting and i looking the pproperties and the link is really C:\Program Files\Autodesk\AutoCAD 2026\acad.exe
Message 13 of 19
bradeneuropeArthur
And when you copy paste that string "C:\Program Files\Autodesk\AutoCAD 2026\acad.exe" in windows explorer?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 19
SergeLachance
autocad open
Message 15 of 19
bradeneuropeArthur
then please try the next thing:
use a new code of i-logic
Process.Start("notepad.exe")
 does this start notepad?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 19
SergeLachance
yes
Message 17 of 19
bradeneuropeArthur
@johnsonshiue do you have any ideas?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 19
CGBenner
@SergeLachance
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Message 19 of 19
SergeLachance
no one resolve my problem again!
