When I try to chamfer this edge.
It won't let me pick another edge to complete the dimension. Its the only dimension that's missing but also the tire pattern itself. I have no idea how to dimension tire patterns since the pattern is not "flatted".
Here are the files if you want to take a look.
Solved by bradeneuropeArthur. Go to Solution.
Because it is not a chamfer I assume. it is only an angle!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
you need to see the chamfer from side-view not from top in a drawing!
Arthur Knoors
I forgot to ask, do you have any suggestions on how I could dimension the tire pattern? I have no idea how to do it since its not a flat pattern.
Do you have a pdf with what pattern you mean?
Arthur Knoors
I posted a screenshot of the pattern on the post with the drawing file and ipt file as well.
Cannot open it I am on Inv 2018.
Pdf would be ok
Arthur Knoors
You mean this pattern?
To my opinion this is not needed because of symmetry like flanges.
Otherwise I would indicate an angle between them.
Or I would export the pattern parameter and indicate it with 7x.
Arthur Knoors
