Inventor Forum
Why cant I dimension the chamfer on this drawing and how can I dimension this tire pattern?
11 REPLIES 11
Message 1 of 12
1389 Views, 11 Replies
When I try to chamfer this edge.
It won't let me pick another edge to complete the dimension. Its the only dimension that's missing but also the tire pattern itself. I have no idea how to dimension tire patterns since the pattern is not "flatted".
Here are the files if you want to take a look.
11 REPLIES 11
Message 2 of 12
bradeneuropeArthur
Because it is not a chamfer I assume. it is only an angle!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 3 of 12
in reply to: bradeneuropeArthur
It is chamfer with an angle of 45 degrees.
Message 4 of 12
bradeneuropeArthur
you need to see the chamfer from side-view not from top in a drawing!
Arthur Knoors
Message 5 of 12
Oooooh i see now, I just solved it, thank you!
Message 6 of 12
I forgot to ask, do you have any suggestions on how I could dimension the tire pattern? I have no idea how to do it since its not a flat pattern.
Message 7 of 12
bradeneuropeArthur
Do you have a pdf with what pattern you mean?
Arthur Knoors
Message 8 of 12
I posted a screenshot of the pattern on the post with the drawing file and ipt file as well.
Message 9 of 12
bradeneuropeArthur
Cannot open it I am on Inv 2018.
Pdf would be ok
Arthur Knoors
Message 10 of 12
Here it is!
Message 11 of 12
bradeneuropeArthur
You mean this pattern?
To my opinion this is not needed because of symmetry like flanges.
Otherwise I would indicate an angle between them.
Or I would export the pattern parameter and indicate it with 7x.
Arthur Knoors
Message 12 of 12
No I mean the emboss pattern around the tire. See the photo under.
