Inventor Forum
Tangent constraint puts parts in inverse alignment
8 REPLIES 8
Message 1 of 9
Vagulus
418 Views, 8 Replies
I have a cam plate with two tracks on it
At the end of a cross-shaft a bearing (red arrow) is to ride between the faces of the cam track walls (green arrows)
That's the theory, anyway Smiley Wink.  Using a Tangent Constraint I constrain the outer face of the bearing
to one cam track wall
and the bearing immediately jumps to the wrong side of the cam face wall.  FTR: the bearing follows the track perfectly except that it is outside the track instead of inside it Smiley Mad.
How do I get the follower bearing to stay in the right place (between the cam track walls)?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
8 REPLIES 8
Message 2 of 9
Vagulus
in reply to: Vagulus
Relax, folks.  I got it.  The buttons for internal or external tangent are the wrong way round.  I did it all again clicking the wrong button and it worked perfectly.  Has Microsoft bought Autodesk? Smiley LOL
Albert Einstein
Message 3 of 9
SBix26
Can you post your parts?  It sounds as if you have backward surface normals or something.  The buttons are not the wrong way around in my experience.
Sam B
Inventor Pro 2019.1.1 | Windows 7 SP1
LinkedIn
Message 4 of 9
Vagulus
in reply to: SBix26
Herewith
Albert Einstein
Message 5 of 9
martin.jacko
I took a look at your problem.
It seems there is something wrong with derived component.
Do you remember how do you create derived component?
In inventor 2019 I tried to create another one from AE-001-0003.ipt, but tangent constraint works fine.
Martin
Message 6 of 9
Vagulus
in reply to: martin.jacko
New --> Std. (mm) ipt --> Create -->  Manage --> Derive --> select part to derive from --> OK
Albert Einstein
Message 7 of 9
Vagulus
in reply to: SBix26
Here's something else which is the wrong way round.
Here I have a vertical line, but the icon shows that it is constrained horizontal.
Now, I know that Australia is 'Down Under' but I didn't know that that means the software has to work back to front.  Smiley LOL
Albert Einstein
Message 8 of 9
martin.jacko
It looks like problem of inventor 2018 derived component.
Could you please try to derive and use tangent constraint on inventor 2019 (trial)?
Martin
Message 9 of 9
Vagulus
Hi Martin
Thanks for your interest.
I had the same issued with 2010 and 2015.
I have 2018 working okay and I can live with the issues now I have identified them.  Changing versions of AI sounds like an invitation to heartache getting it up and running.  I will let sleeping dogs lie.
Albert Einstein
