Table from Excel, no merging allowed?
cbenner
Mentor Mentor
Message 1 of 14
cbenner
http://forums.autodesk.com/t5/inventor-forum/excel-spreadsheets-into-drawings/m-p/5631220/highlight/...
Referencing this old thread, I have a similar but more infuriating problem today.  A user tried to place a spreadsheet onto a drawing, and only got the top row of data.  Fiddling with the spreadsheet and my Inventor table settings, we discovered that the table only worked when all merged cells in the Excel file were removed.  The results are, to say the least.... dog ugly.  Is there something I am missing here?  Because I can't believe that the technology doesn't exist to place a spreadsheet that includes merged cells onto an Inventor drawing... especially this far into the game.
Replies (13)
Message 2 of 14
Curtis_W
Hi cbenner,
Someone can correct me if I missed something recently, but as far as I know merged cells are indeed not supported.
I hope this helps.
Curtis
Message 3 of 14
MechMachineMan
Definitely does kind of suck that it doesn't account for the merged cells. However, merged cells are a huge PITA because they do cause almost anything in VBA to act funny.
If you want to spreadsheet to still look the same, but function properly, it might be worth swapping to using "Center Across Selection" instead of merging cells.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 14
cbenner
Center Across also did not work.  But thanks for the suggestion.
Message 5 of 14
cbenner
Thanks @Curtis_W...
It just BLOWS my mind that in 2017, to get a spreadsheet for ASME welding data onto an Inventor drawing, in the format in which it was given to me... I have to go old school OLE object!
@ChrisMitchell01 really?
Message 6 of 14
Mark.Lancaster
@cbenner
I could be way off and my old mind is playing tricks on me..  Smiley Very Happy
But I remember a while back someone was having issues with a Inventor table and excel.  In the end the problem was related to having blank cell columns and rows in the excel spreadsheet.  Which led the table in Inventor to be truncated.  So in theory when you merge cells in excel, I was thinking that Inventor is still seeing those merged cells as separate ones and the extras are seen as blanks and thus the failed output.  But I could be wrong..
Mark Lancaster
Message 7 of 14
cbenner
@Mark.Lancaster wrote:
@cbenner
@Mark.Lancaster  I think the thread you are referring to is the one linked in my original post... in which I wrote the solution.  It may well be that merged cells are seen as blank.  But that doesn't make it better.... I should be able to link an Excel spreadsheet as created.  It works with no trouble in AutoCAD, but Inventor chokes on it.  And this is not the time for me to start changing all of my idw's to dwg's.  Thanks for the thoughts, Mark.
Message 8 of 14
Mark.Lancaster
@cbenner  Sorry my bad..  Smiley Sad  Was in a rush and didn't click on the link you provided.
Mark Lancaster
Message 9 of 14
Hi Cbenner,
Any updates on this issue?
Its kind of frustrating thou. Even in 2018 this functions still not implemented.
Message 10 of 14
Mark.Lancaster
@Anonymous
Nothing has changed..
Mark Lancaster
Message 11 of 14
johnsonshiue
Hi Guys,
Has it been submitted as an idea on Inventor Ideas forum?
Many thanks!
Software Test Engineer
Message 12 of 14
@MarkLancaster,
Thank you for the update.
I just find it very frustrating as, this functions is very useful to us users and Autodesk did not do anything for the past years or releases. Whilst in AutoCAD this functionality works perfectly.
Message 13 of 14
andrewdroth
Inventor seriously lacks in the table department.
And for creating technical documents it's almost as bad of a joke as the revision cloud.
It's well documented in the Idea Station.
https://forums.autodesk.com/t5/inventor-ideas/better-table-feature-in-idw/idi-p/4392231
https://forums.autodesk.com/t5/inventor-ideas/table-into-drawing/idi-p/6704386
https://forums.autodesk.com/t5/inventor-ideas/custom-tables/idi-p/6460702
https://forums.autodesk.com/t5/inventor-ideas/please-fix-and-improve-the-drawing-table-behaviors-in-...
https://forums.autodesk.com/t5/inventor-ideas/text-options-in-a-table/idi-p/5670396
Inventor needs a real table editor. Like AutoCAD has.
Currently, our best approach for creating tank design data tables is;
  • Create an Excel Table
  • Print to PDF
  • Save PDF as an image
  • Paste image in IV.
As you can image editing our tables is tedious, but this is the best IV can do.
It's terrible.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Message 14 of 14
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2025. Please review the Inventor 2025 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
