Close
There are many things about Inventor drawing tables I'd like to see some change for years:
I find many posts before about these problems in this forum, please just fix it! I think it it not good to tell our customer again and again that, "We need to change our company standard a litte bit, because Inventor cannot do that!"
Some posts I find, I think there are more:
http://forums.autodesk.com/t5/Inventor-General/How-to-set-parts-list-row-height/m-p/2278832#M303567
http://forums.autodesk.com/t5/Inventor-General/Revision-table-row-heights/m-p/2049008#M268485
http://forums.autodesk.com/t5/Inventor-General/Line-weights-in-Parts-List/m-p/2454186#M335964
Hi we have various tables and parts lists we use on our drawings and all use the same text styles and spacings etc. However when a Parts List is positioned next to a General Table (image attached) you can clearly see that none of the rows are at the same heights. The General Table seems to work as expected for the Row Heights based off of the text heights and gaps etc, but the Parts List is just completely out. Is there a way to get them to match if not we think its something that would be a benefit.
Hello j.peterszetapdm,
Although your Idea was authored earlier, I am closing it as a Duplicate of the following Idea: http://forums.autodesk.com/t5/inventor-ideastation/please-fix-and-improve-the-drawing-table-behavior...
Please visit it and cast your cudo as to not split votes for this request. Thanks! -Dan
I had an email to say that this idea has been accpted - great job everyone!
Don't stop giving this idea Kudos, we need to take it to the front of the que ;)
Paul
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Share and shape product ideas.
Please review our Idea guidelines and best practices before posting a new idea, or voting on an existing one!
Autodesk is a leader in 3D design, engineering and entertainment software.
